Crisper drawer for Kenmore Coldspot refrigerator model 106.53634300 Drawer part number probably...
(More)
Crisper drawer for Kenmore Coldspot refrigerator model 106.53634300 Drawer part number probably 1021812
Hello, My freezer in not functioning. Fridge at 60 degrees. Every few minutes it hums and there is a...
(More)
Hello, My freezer in not functioning. Fridge at 60 degrees. Every few minutes it hums and there is a power draw, then stops. The compressor is not coming on.
what would cause a tempered glass refrigerator shelf to shatter when the fridge is turned off and...
(More)
what would cause a tempered glass refrigerator shelf to shatter when the fridge is turned off and there is nothing in the fridge?
Last night I came home to find water all over the floor under my fridge, a bottom freezer kenmore....
(More)
Last night I came home to find water all over the floor under my fridge, a bottom freezer kenmore. The whole thing was iced over inside, and the door partially open. I cleaned it up and closed the door. This afternoon I came back to find water all over the floor again, the freezer ice-bound, and water running out of the icemaker. The icemaker stopped making ice about a year ago, although it sometimes makes noises like it is making ice. Right now, there are ice cubes in the freezer, so it must have started to work again. I pulled the plug connecting the icemaker to the back of the freezer, and set the arm to stop ice.
Vegetables freeze in the winter and I don't know which way to turn the knob on the back of the...
(More)
Vegetables freeze in the winter and I don't know which way to turn the knob on the back of the fridge side to make it less cold. This is a Kenmore freezer on the bottom. Thanks.
Every time we close the top refrigerator, the bottom freezer pops open. As of the past two...
(More)
Every time we close the top refrigerator, the bottom freezer pops open. As of the past two nights, I have woken up with it open and the refrigerator turned itself off at the outlet.
Need help..I just moved, and made a few mistakes, I wonder if I did something irreversible. first I...
(More)
Need help..I just moved, and made a few mistakes, I wonder if I did something irreversible. first I got a Kenmore fridge out of storage (6 months) and put it sideways to transfer to my new house,
also due to the fridge being dirty I decided to "hose" down the inside
and outside, now to to my surprise I turn on and the freezer is working
but the refrigerator is not. there is no leakage or fluids coming out,
there is no ice buildup anywhere, I can hear/see the fan running in the
back, again the freezer is cold as Alaska and the fridge is hot as
Florida, please tell me I don't need a new fridge!, I wonder if the
hosing down clog something, I cant feel any air coming to the fridge
from anywhere!! the fridge has been plug for 6 hours now, PLEASE
HELP!!!
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
