20 Most Recent
Abit GD8 Motherboard Questions & Answers
GD8 motherboard
The GD8 mobo spec says that the bopard is only compatible with P4 and Celeron D processors so no you cant swap it! Generally the Athlon 1800+ is a better processor but it depends on the mobo, BIOS, RAM setup etc.
9/9/2009 7:03:17 PM •
Abit GD8...
Answered
on Sep 09, 2009
Hardlocked;beeping and red light on motherboard;will not restart
Something on the motherboard has failed, and the RED light confirms it.
Turn your computer off.
Remove ALL of the RAM. Turn your computer on.
Do all the fan(s) start to spin?
Do you get the _same_ "beeps" as before, or some different pattern of beeps?
If it has more than one stick of RAM (and the RAM is _NOT_ labelled 'DDR2'),
then remove all but one stick of RAM, turn your computer on, and try to reboot.
Same beeps?
Turn your computer off, try a different single (or pair of) sticks of RAM.
Caution: before doing any of the above, your computer could be within the "WARRANTY" period,
i.e., it could be fixed/replaced for free!
5/27/2009 8:07:00 PM •
Abit GD8...
Answered
on May 27, 2009
How to connect 2 cd-roms to motheroard
If they use the wide ribbon cable, you need the cables with two connectors. Then set on drive to master and one to slave, or set both to CS - for cable select. When you restart the computer, the OS will do the rest.
Kds monitors support
Hi Klex,
I was able to find the website address
www.kdsusa.com through one of their products on Newegg, but the site appears to no longer exist. They also had a phone number listed (1-800-283-131) but that too doesn't seem to work. I have the feeling that they have either close their business or ended their operations in the U.S..
Sorry I didn't have better information for you.
