20 Most Recent Kenmore 63263 Microwave Oven Questions & Answers
Making loud sound when turntable
That sounds like there is a short in the high voltage section (like 3500 Volt!). The most likely part to be bad is the diode. That is a small part, probably round, about 5/16" OD and about an inch long with two wires coming out of it. It should show continuity one way, but NO continuity the other way. If it shows continuity both ways then it (noisily) bleeds off the high voltage. The diode is connected to a capacitor which could be shorted. Then there are two wires running from here to the magnetron, which could be shorted (there should be no continuity from either terminal to the outside of the magnetron). Of course, also the transformer could be shorted, but not likely. If you take out the diode, turn on the oven and it makes no noise, then the Xfrmr is OK. Did this help?
9/7/2011 5:10:18 AM • Kenmore 63263... • Answered on Sep 07, 2011
How do I remove the
Hi! The best solution that i know is to wash it with vinegar, a simple vinegar will do it. Leave it with the vinegar on for about 2-3 minutes then wash it again with a regullar cleaning solution mixed with water. After that, rinse with plain water. This works great on fridges also...
I hope that will help you! Have a nice day!
9/2/2011 1:13:09 AM • Kenmore 63263... • Answered on Sep 02, 2011
I've had my oven for
Hello Pam. Go to this diagram of your microwave and you will see part number 5015 which is the bulb and it's location in the ceiling of the microwave. Joe
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Microwave-Parts/Model-72163263301/0582/0123245/P0810072/00005?blt=06&prst=&shdMod=
11/15/2010 3:46:10 PM • Kenmore 63263... • Answered on Nov 15, 2010
Microwave won't function.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Also see http://www.microwavedisplay.com/doorsw.txt
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
12/12/2008 11:48:00 PM • Kenmore 63263... • Answered on Dec 12, 2008
Kenmore microwave uneven base
It seems that when you bought the microwave the metal or plastic on the bottom of the unit is bent or warped. If I were you I would return it because yo cant really fix it
1/1/2008 5:31:34 PM • Kenmore 63263... • Answered on Jan 01, 2008
Kenmore microwave model 721.85033010 works fine except the exhaust fan comes on just out the blue for no reason and wont shut off without unplugging.
It turns itself on
  1. Interlock switch If your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control board If your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
But before throwing parts at it give these folks a call... https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Microwave/74-6-878350-/New/Kenmore-Microwave-Turns-On-By-Itself-721-85033010 Best to you
9/2/2023 9:10:40 PM • Kenmore... • Answered on Sep 02, 2023
Looking for manual for a Kenmore Viking 851.8250800 Microwave.
It looks like it is too old. Nothing in Kenmore or Viking. https://www.google.com/search?q=Kenmore+Viking+851.8250800+manual ..
8/7/2023 7:31:34 PM • Kenmore... • Answered on Aug 07, 2023
Kenmore over the range microwave tripping breaker
You've found the proper location if you're seeking for the fuse for your Kenmore microwave. The fuse is often found in the microwave's or behind the control panel. You must take off the microwave's exterior cover in order to reach it. After you've identified the fuse, you may see if it has blown. If so, you'll have to swap it out for a new one. It might be preferable to seek professional advice if you are unsure on how to proceed.
4/18/2023 8:31:03 PM • Kenmore... • Answered on Apr 18, 2023
2answers
When trying to use convection with Kenmore hood combination it stars then stops and the display says F-5. What does that mean
If you are getting an F-5 error code on your Kenmore hood combination, it typically indicates a problem with the temperature sensor. This error code may occur when you are trying to use the convection feature, as you have described.
To troubleshoot this issue, try the following steps:
Turn off the power to the unit and unplug it from the electrical outlet.
Wait a few minutes, then plug the unit back in and turn on the power.
Try using the convection feature again and see if the error code reappears.
If the error code persists, you may need to replace the temperature sensor. You can consult the user manual for your Kenmore hood combination or contact Kenmore customer service for assistance with this.
If the unit is still under warranty, it's recommended to contact Kenmore customer service for repair or replacement options.
4/5/2023 7:13:24 AM • Kenmore... • Answered on Apr 05, 2023
Need a replacement display board for a Kenmore Microwave Model No. 318279601B
These are all the top suppliers, but that model number is not showing. If the display has gone dim, you can get an electronics technician to replace the capacitor that runs the display. https://www.google.com/search?q=Kenmore+Microwave+318279601B+parts ..
3/11/2023 7:20:22 PM • Kenmore... • Answered on Mar 11, 2023
My Kenmore stove timer started going off every 45 seconds
It sounds like you may be experiencing an issue with your Kenmore stove's timer function. Here are a few steps you can try to resolve this issue:
Check the timer settings to make sure that the correct time and alarm settings have been entered.
Try resetting the timer by turning it off and back on again, or unplugging the stove and waiting a few minutes before plugging it back in.
Make sure that there are no buttons or knobs stuck on the stove, as this could cause the timer to activate repeatedly.
If these steps do not resolve the issue, it may be necessary to contact a professional appliance repair service for further assistance.
2/1/2023 2:26:53 AM • Kenmore... • Answered on Feb 01, 2023
I have a Kenmore over the range microwave oven and it is not powering on after a power outage. What could be causing this please?
Question edited for spelling of Kenmore and typos. Question moved from Kenmore Washing Machines. All about repairing microwave ovens https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
1/22/2023 1:47:03 AM • Kenmore... • Answered on Jan 22, 2023
I need user manual for Godrej 20E 08 SLGX microwave oven
I have a godraj 20E 08 SLGX MICROVIEW OVEN .Can you plz tell me can I bake in this if yes then how i preheat it for baking
1/12/2023 3:13:10 PM • Kenmore... • Answered on Jan 12, 2023
From top to bottom, what should be the types of door interlock switches on a Kenmore microwave 790.803.
Maybe get the part here? https://www.partselect.com/Models/790803/
12/30/2022 6:16:41 PM • Kenmore... • Answered on Dec 30, 2022
Where can I find the specs for a Kenmore oven model # 326B1016P001.
That is the strangest model number for a Kenmore and doesn't follow the normal 3 dot 7 ***.******* format of others. Just measure the front of what you have. They come in standard sizes. https://www.google.com/search?q=kenmore+%22326b1016p001%22+installation+manual ..
12/10/2022 8:00:48 PM • Kenmore... • Answered on Dec 10, 2022
Kenmore microwave model 401.85053010 won't heat or cook anything.
Unfortunately, this is not something that can be diagnosed from a distance, unless you had access to a "Kill-a-Watt" meter or equivalent. It could be caused by a bad door switch, a bad relay on the main board, a bad magnetron, or a bad HV diode. (The HV capacitor is probably OK, because if it were bad [shorted], it would blow fuses.)
10/28/2022 6:00:32 AM • Kenmore... • Answered on Oct 28, 2022
Kenmore 63263 Microwave Oven Logo
20 questions posted
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Microwave Ovens
Most Popular Question
microwave function
  • Microwave Ovens
