20 Most Recent
Danze D500556RBT Oil Rub Bronze Bannockburn?? Single Handle Pressure Bala Questions & Answers
Danze D500044 switch control arm loose, can't switch the water from shower head to bathtub, how to fit it ? Thanks
you may need to adjust the diverter cartridge on the valve to fix the switch control arm. Here are the steps to do so:
Turn off the water supply to the faucet and open the valve to release any residual pressure.
Remove the handle by loosening the set screw with an Allen wrench and pulling it off.
Unscrew the bonnet nut and remove the diverter cartridge by pulling it out with pliers.
Check the O-rings and seals for any damage or wear and replace them if necessary.
Align the diverter cartridge with the valve body and push it in firmly until it snaps into place.
Screw the bonnet nut back on and tighten it with a wrench.
Reattach the handle and secure it with the set screw.
Turn on the water supply and test the faucet for proper operation.
I hope this helps you fix your faucet. If you need further assistance, please contact Danze customer service at 1-888-328-2383.
3/7/2024 3:37:36 PM •
Danze Home
Answered
on Mar 07, 2024
Danze faucet jerks
being a new faucet it does that because you still have air in the line. turn the faucet on and let it run for a while, if that doesn't work take it back and get a better quality faucet like a delta, because they make them so cheap that the seal could be loose inside.
3/31/2019 3:50:35 PM •
Danze Home
Answered
on Mar 31, 2019
On OpulenceTM SHOWER Trim Kit w/8incg Sunflower
Either this is a consequence of having a "low-flow" shower head, or the pipes are too small or have too many bends and elbows to support the flow rate required at 65 PSI for such a large shower head. What is the water pressure at the shower head fitting while the shower is running? It won't be 65 PSI, but it shouldn't be below the recommended inlet pressure for the unit.
2/27/2018 4:55:18 AM •
Danze Home
Answered
on Feb 27, 2018
New danze cartridge no water
Possible issue with pressure balancing cartidge, When you remove parts, turn off water, remove parts, slowly turn on water and see if brass valves lets water out. If yes pressure balancing cartridge or cartridge itself is defevtive.
8/16/2014 10:32:51 PM •
Danze Home
Answered
on Aug 16, 2014
Shower head holes clogged up
unscrew head with cresent wrench...soak head in viniger over night....this should clear holes...wash out...if has restrictor...remove and replace using teflon tape..
5/22/2014 11:23:43 PM •
Danze Home
Answered
on May 22, 2014
Danze UPC tub/shower valve leaks
shut off water and pull cartridge...go to lowes or plumbing supply and match up cartridge and replace...you may also just replace seats and springs if cartridge is ok....cheaper...but if not sure just replace whole cartridge...make sure hot is on left...
5/22/2014 9:59:26 PM •
Danze Home
Answered
on May 22, 2014
