20 Most Recent KitchenAid 34 in. KUDV24SE Built-in Dishwasher Questions & Answers
During normal operation the outlet hose should be higher than the outlet nozzle, if the water drains when youremove the hose it means that the pump is not working, open the bottom of the machine and remove the inlet side pump hose and check for any obstruction, clean and replace the hose. If this does not work you need to replace the pump.
KitchenAid 34... | Answered on Jun 02, 2011
I think you want to disable the childlock key. I think all you need to do is press the child lock key for 5-6 secs .That should disable the child lock.
KitchenAid 34... | Answered on Jun 01, 2011
ReplACE the lower door seal.
KitchenAid 34... | Answered on Apr 22, 2011
You could buy it from :-
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=385148&ST=PBM
It is in stock as per them.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
KitchenAid 34... | Answered on Mar 02, 2011
If you have still have some hard water present, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
KitchenAid 34... | Answered on Mar 01, 2011
looks like a very tight spot to be in. Your best bet is to get the toe panel off (item 8) in this diagram. and then carefully release the springs (item 6) on each side with a nose plier.
This should free up the door at the bottom. If not, then try to drop the levelling screws (item 16) in this diagram. and see if that allow you drag the dishwasher out from under the bench.
KitchenAid 34... | Answered on Jan 04, 2011
Sound like the is a problem with one of the supply pipes for the water check they are not blocked and the is no turn off on
KitchenAid... | Answered on Jul 06, 2019
There are several touch pad buttons that could activate the Child Lock feature on a Kitchenaid dishwasher. To toggle off the lock, try pressing and holding the 4-hour delay dry or the energy saver dry key pads for 4+ seconds. The Energy Saver Dry is used for the Child Lock on the Kitchenaid KUDS25SHWH1. This manual is here: https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L9050329.pdf . The 4-hour delay or Control Lock options are listed in this manual: https://www.kitchenaid.com/content/dam/global/documents/201605/owners-manual-W10596243-RevD.pdf . If neither of these steps work, you may have a problem with the keypad, the wiring between the keypad and the control board or the control board itself.
Please add a comment with the model of the dishwasher if you'd like me to try and find the parts list/diagram. If the machine is under warranty, you may want to contact Kitchenaid.
I hope this helps.
KitchenAid... | Answered on Jun 30, 2019
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
KitchenAid... | Answered on Jun 22, 2019
Sounds like control board failure
KitchenAid... | Answered on Jun 13, 2019
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
KitchenAid... | Answered on Jun 05, 2019
The blinking usually happens when your house power goes off and then comes back on. Press the Start/Cancel Button to reset.
KitchenAid... | Answered on Jun 04, 2019
Dishwashers Logo
12 questions posted
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
model kudv245ewhy key pad
  • Dishwashers
