20 Most Recent KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher Questions & Answers
Getting it out of child lock can be difficult but make sure you watch the light on the front panel it will go right back to lock if your not careful.I had to try several times at first I thought it would need a doctor.. but with patience it should work and unlock with the 4 second hold.. power down does not reset unless you wait 30 minutes or longer.. hope this helps
KitchenAid 24... | Answered on Oct 13, 2013
Go to www.applianceart.com
They have many options available for changing the color of your Kitchen Aid dishwasher. They also have designs, textures and stainless steel.
KitchenAid 24... | Answered on Sep 07, 2011
Hi
If the drain pump is clean and the water inlet valve is fine then the issue is with the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
KitchenAid 24... | Answered on May 22, 2011
Hello- This unit has a sump at bottom of tub that can get blocked, causing low or no water flow. Remove racks, water tube, and the accumulator cover to get to it. Clean the strainer and chopper screen. This should solve the problem. Let me know if this info helps- have more if needed. -Thanks- Ed
KitchenAid 24... | Answered on May 01, 2011
I had this and the thermal fuse needed to be replaced ($14 part).
If the lights won't come on on the controller and you are sure you have power to the dishwasher, then check the thermal fuse.
1. turn off the power to the machine
2. open the door and unscrew all the screws along the inner edge
3. gently split apart the layers of the door and access the controller; it is inside the door and just below the buttons that are supposed to light up.
4. the thermal fuse is white and clipped onto the side of the control box close to the top of the door.
5. unplug the leads going into it and check it with a multimeter - if no current goes through it then it needs to be replaced
relatively easy fix - good luck!
KitchenAid 24... | Answered on Oct 31, 2010
HI. The control board was actually not the issue here. The interface will be the lone culprit in this case. There is a stuck circuit or button that is causing this warning(blinking lights). The button is mounted on the interface and you will need to, simply, replace the interface board. Once this is done, the unit will operate normally.
Click here to purchase your new interface board on line, if you wish.
KitchenAid 24... | Answered on Jul 30, 2010
measure the voltage to the water fill valve. it should be about 120 volts in fill mode. if it is, then the inlet screen may be plugged. turn off water and disconnect pipe. examine and or clean screen. if screen is clean (some may not have one) and it has 120 volts applied to it then you need to replace the fill valve.
KitchenAid 24... | Answered on Oct 27, 2009
try the reset button sequence.. described in that other post about the clean light blinking.. that will reset the whole machine..
tpug
KitchenAid 24... | Answered on Mar 03, 2009
You will need to bring the DW about 8-10 inches out from under the counter to access the door springs on the side of the unit.
Any questions, let me know
Please take the time to give this solution a fix ya rating
clarkco
KitchenAid 24... | Answered on Feb 27, 2009
try the reset button sequence i posted in the other question..
KitchenAid 24... | Answered on Jan 31, 2009
dishwashers need alot of water ..check hoses for blockage and water pressure...should be around 40. also check and see if proper drainage. water has to get to the top by hoses to a sprayer check that...a motor has to run the sprayer,that looks like a 2 blades whirling about with holes, and might have clutches and gears worn in that cycle...you will stand there and hear all the cycles and can open it to see if top gets water. good luck
KitchenAid 24... | Answered on Jan 24, 2009
KitchenAid 24 in. KUDI01FL - Multiple Color Built-in Dishwasher Logo
37 questions posted
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
blinking clean light
  • Dishwashers
