KitchenAid KSBP25FKSS Side by Side Refrigerator
Problems with KitchenAid KSBP25FKSS Side by Side Refrigerator?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
KitchenAid KSBP25FKSS Side by Side...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for KitchenAid KSBP25FKSS Side by Side Refrigerator RSS Feed
View More Results for KitchenAid KSBP25FKSS Side by Side Refrigerator
Questions and Unsolved Support Problems
Unsolved Problems for KitchenAid KSBP25FKSS Side by Side Refrigerator RSS Feed
Answer
Suddently, the thru-the-door ice/water/light stopped working
Answer
Our freezer stopped freezing - everyting is thawing!! It's double-sided, and the strip between the... (More)
Answer
How to remove dispenser cover panel from Kitchenaid Side by side refer - KSBP25FJSS00?
Answer
ice maker water dispensor not working on kitchenaid ksbp25fkss00
Answer
the light inside the fridge turns off. I have to press holiday mode twice to get the light to turn... (More)
Answer
my kitchenaid side by side refrigerator and freezer not cooling or freezing
Find a Manual
KitchenAid KSBP25FKSS Side by Side Refrigerator Manuals & Guides
Tips & Tricks
(Post a New Tip)
Save energy and your appliances...i.e. air cond and refrigerators
This is just a simple tip that will help you save energy and make your high dollar appliances last longer. This tip applies to refrigerators,... written by tdulany
Refrigerator problems
Water is pooling up under the crispers: defrost drain is stopped up. When the ice box defrosts the water has to go somewhere. If the drain is... written by TheMobilian
Refrigerator or freezer not cooling/ running continuously
When a refrigerator or freezer isn't cooling correctly, especially if it is running continuously, the first thing to check is the condenser. It will... written by wiringlunati
freezer freezes but refrigerator will not cool.
If you are having trouble with the freezer working fine but the refrigerator not cooling then the defrost has not cleared all the ice in the coils.... written by cj2176
Doing It Yourself
Many people think they can fix their appliances, but you really should think twice. Tearing into your fridge can be a disaster, weigh the cost of... written by snuffy01
what do do if your fridge/freezer is not cold
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not... written by projdoc
How to repair a defrost system.
Is there ice/frost build up at the rear inside of the freezer? (If not go to the evaporator fan). You are having a problem is with your defrost... written by mgprice
How to clear a blockage in the defrost drain.
Remove the shelfs and food from the freezer then take out the panel at the back/bottom of freezer. You will see ice build up in the drain pan below... written by mgprice
WikiManual
(Post a New Chapter)
How to Defrost a Freezer Fast
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the... by wikihow
How to Get Rid of Bad Smells in Your Refrigerator
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no... by wikihow
How to Clean a Refrigerator
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have... by wikihow
How to Repair a Clogged Ice Maker
If you're missing that certain chill in your life, follow these steps to repair your ice maker. You'll be on the rocks again in no... by wikihow
How to Fix a Common Refrigerator Problem With Just the Palm of Your Hand
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do. Steps: 1. Check that the knob is... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for KSBP25FKSS Side by Side Refrigerator
Nationwide | 423-303-3782 | Website
Refrigerator parts delivered overnight nationwide. Ori... Read More
Featured Listing
Nationwide | 6506169292
Featured Listing
Nationwide | 816 4715334 | Website
* Please Contact us for More Information
Featured Listing
Nationwide | 6195644488
Featured Listing
Nationwide | 210 6582801 | Website
Rate and Review the KitchenAid KSBP25FKSS Side by Side Refrigerator
Write a review:
Rate this product:
Would you recommend the KSBP25FKSS Side by Side Refrigerator to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for KitchenAid KSBP25FKSS Side by Side Refrigerator
Key Features
Type
Side by Side
Total Volume
24.5 cu. ft. / 694 liter
Fresh Food Volume
14.9 cu. ft. / 422 liter
Freezer Volume
9.6 cu. ft. / 272 liter
Ice Maker
Without Ice Maker
Fresh Food Compartment
Door Opens
Opens to Left and Right
Dimensions
Overall Depth
29.37 in.
Overall Height
72.25 in.
Overall Width
35.5 in.
Warranty
Warranty
1 Year Parts and Labor · 1 Year Parts · 90 Days Labor
KitchenAid Contact Information
Main support number1-800-422-1230, 1-800-541-6390
Describe your problem:
Top Refrigerators Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
