I have Whirlpool fefrigerator model GS5SHAXNL00, the maker used to work for a while and stop for a...
(More)
I have Whirlpool fefrigerator model GS5SHAXNL00, the maker used to work for a while and stop for a while leaving the ice jamed in the mold. Mechanic found the know on the side of the icemaker broken. I replaced with brand new icemaker but now I noticed the water is not filling when you get water on the door. Any solution?
I want to test run the compressor ,the starter is burned up copressor ohms out ok run capacator...
(More)
I want to test run the compressor ,the starter is burned up copressor ohms out ok run capacator tests good how can i test run compressor to make sure it is good? it has 3 pins on it not sure which ones to use??
This thing runs almost constantly but unless it has a separate compressor for the freezer and...
(More)
This thing runs almost constantly but unless it has a separate compressor for the freezer and another for the refrigerator, the compressor seems to working fine. The freezer side stays at a temperature well below "frozen" (roughly 5
degrees below zero F). On the hand, I can't get the refrigerator to go much below +50
degrees F. I have the freezer set at the lowest available setting (highest temperature) which is 1 on the scale of 1 to 4. I have the refrigerator set at the highest available setting (lowest temperature) which is 4 on a scale of 1-4. If I close the freezer and the refrigerator doors at the same time, both the freezer & the refrigerator doors will **** themselves in evenly but after a short period of time the refrigerator door seems to lose its seal and will stick out maybe a quarter of an inch beyond the freezer door. If I just open and close the refrigerator door by itself it doesn't **** in at all and still sticks out beyond the freezer door that same quarter of an inch. Are there air passages that move air between the two compartments that maybe could get blocked (maybe full of ice or something) and in doing so keep the colder air from the freezer side from reaching the refrigerator side & the warmer air from the refrigerator side from reaching the freezer side?
Hello. My freezer/fridge has suddenly warmed up since yesterday. Upon waking this morning, the...
(More)
Hello. My freezer/fridge has suddenly warmed up since yesterday. Upon waking this morning, the freezer is now warmer than room temp. The fridge is not warm, but not really cool either. The lights come on, and no warning lights are illuminated. What is wrong? This stupid thing is not even five years old. It was only delivered in September 2003 (I think). Is it a fuse? Is it the compressor? I am trying to keep all of my food from spoiling, but I need to put it back at some point! HELP!!!
There is a red light inside the freezer and it is flashing. It is not cold inside. The refrigerator...
(More)
There is a red light inside the freezer and it is flashing. It is not cold inside. The refrigerator side works.
there is a water line connector at bottom of fridge but don't know where it hooks up. Can you help?...
(More)
there is a water line connector at bottom of fridge but don't know where it hooks up. Can you help? It's a Kitchenaid Superba side by side with ice and water dispensers.
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
