20 Most Recent
Moen & Monticello& Two Handle Lavatory Faucet Questions & Answers
Monticello cold tapfell off -rubber
Call: 1-800-Buy-Moen (1-800-289-6636)
8:00 am to 8:00 pm EST Monday thru Friday
9:00 am to 5:30 pm EST Saturday
Closed on Sundays and all nationally observed holidays.
To contact Moen Canada call: 1-800-465-6130
8/20/2011 8:38:08 PM •
Moen &...
Answered
on Aug 20, 2011
How do you remove the handle to gain access to the
There is a set screw on the base of each handle, on the backside, which needs to be loosened with an allen wrench (hex-head) lossen the set screw and remove handle.
Please rate this answer for me. Thank you
3/25/2010 8:35:30 PM •
Moen &...
Answered
on Mar 25, 2010
Need to replace handle adapter kit on a Moen
Lowes might carry them but i know a plumbing supply house does for sure. Take center caps off hot and cold handls, then screws everything else should pull right off.
9/29/2009 9:36:49 AM •
Moen &...
Answered
on Sep 29, 2009
Two handle Moen kitchen faucet. Hot side handle
loctite is an excellent product,but you have to have a couple of threads for it to 'lock'! be sure handle is seated[pushed all the way on] or shop a hardware or home improvement store for a replacement screw or a 'self tapping'' screw of the proper size.
9/26/2009 10:49:54 PM •
Moen &...
Answered
on Sep 26, 2009
Why did my Moen 3838 Castleby Four Function Showerhead suddenly start gushing water from the base when in shower mode?
There could be several reasons why your Moen 3838 Castlebar Four Function Showerhead is suddenly gushing water from the base when in shower mode. Some possible causes include:
- Clogged showerhead: If the showerhead is clogged with mineral buildup or debris, water may not be able to pass through properly, causing it to gush out of the base.
- Leaky diverter valve: The diverter valve is responsible for directing water to the showerhead. If it is damaged or worn, water may leak out of the base of the showerhead.
- Damaged showerhead: If the showerhead itself is damaged, water may be able to leak out of the base.
- Incorrect installation: If the showerhead was not installed properly, water may leak out of the base.
- Loose or damaged O-ring: An O-ring is a small ring that seals the connection between the showerhead and the water supply. If the O-ring is missing or damaged, water may leak out of the base.
It is best to check the instruction manual and troubleshoot the issue or contact Moen support if needed. If the issue is not resolved by troubleshooting, it may be best to consult a plumber or contact Moen support for further assistance.
1/28/2023 12:53:12 AM •
Moen Home
Answered
on Jan 28, 2023
Pulled a moen 96909 and replaced with a 1222. the 1222 does not go in the bore far enough to put the clip back in.
It sounds like you are experiencing an issue with the installation of the Moen 1222 cartridge in your faucet. The Moen 1222 cartridge is designed to be a direct replacement for the Moen 96909 cartridge, so it should fit in the same way. If the 1222 cartridge is not going in far enough for you to reinstall the clip, there may be a problem with the cartridge or with the faucet itself.
Here are a few things you can try to troubleshoot the issue:
Make sure the cartridge is oriented correctly: The Moen 1222 cartridge has a specific orientation that it must be installed in to work properly. Make sure that the cartridge is oriented correctly and that the stem is facing the right direction.
Check for any obstructions: Make sure that there are no obstructions in the bore or in the faucet that could be preventing the cartridge from being fully seated.
Make sure the faucet is properly disassembled: If the faucet was not properly disassembled before installing the new cartridge, it may not be seated correctly. Make sure that all of the internal parts of the faucet have been removed before attempting to install the new cartridge.
If these troubleshooting steps do not resolve the issue, it may be necessary to seek the assistance of a professional plumber. It is also possible that the Moen 1222 cartridge is defective, in which case you may need to return it for a replacement.
12/24/2022 12:57:02 PM •
Moen Home
Answered
on Dec 24, 2022
Hot water coming out of tub slow
Two possible options i can think of.
1) the hot water valve at the hot water tank is partially closed. look for a lever that can be opened fully. the valve could have become faulty.
2) a copper line from the tank to the faucet might be bent somewhere in the middle
5/25/2022 8:51:09 PM •
Moen Home
Answered
on May 25, 2022
Best way to clean a moen shower head
https://www.google.com suggests the following link:
https://www.hunker.com/12267493/how-to-clean-a-moen-shower-head
Quoting from link above:
How to Clean a Moen Shower Head
By BRENDAN O'BRIEN
Photos.com/Getty
images
Taking a shower could be hazardous to your health if you do not properly and regularly clean your shower head. According to a study at the University of Colorado at Bolder, your shower head may contain harmful bacteria. But not to worry, with some old-fashion vinegar, elbow grease and about 45 minutes, you can take a shower with peace of mind. Clean a Moen shower head while it is still attached, or remove it before cleaning.
Volume 0%Detached Shower Head
Step 1
Remove the Moen shower head. This may require pliers or vice grips. If you use tools, place a towel or rag over the shower head to protect it from scratches and dents.
Step 2
Remove the cover of the shower head, if there is one. The cover may twist or snap off. Do not force it if it seems stuck. This is not a requirement. You can clean the shower head with still attached.
Step 3
Warm the white vinegar on your stove. Do not boil the vinegar. Gauge how much vinegar you will need by the size of your Moen shower head. You need to fully submerge the shower head in the vinegar.
Step 4
Pour the warm white vinegar in a bowl or bucket. Place the shower head in the bowl and submerge it in the white vinegar. Let it soak for 15 to 20 minutes.
Step 5
Clear the holes in the shower head with a paperclip or thin wire. Clear all of the debris from the holes. Dunk and rinse the shower head back in the vinegar.
Step 6
Rinse the shower head and cover with hot water. Re-install the Moen shower head and cover. Test the shower to make sure you have re-installed it properly.
Attached Shower Head
Step 1
Fill a plastic bag with warm white vinegar.
Step 2
Place the bag over the Moen shower head so it is complete submerged in the warm vinegar. Place a rubber band or piece of tape around the stem, securing the bag to the shower head.
Step 3
Remove after 15 to 20 minutes. Take an old toothbrush and scrub off the mineral deposits and debris. Rinse off the shower head thoroughly with hot water and a wet cloth.
Brendan O'Brien
7/7/2020 7:11:17 PM •
Moen Home
Answered
on Jul 07, 2020
