20 Most Recent
Seth Thomas St. Thomas Creations Daytona Dual Flush Elongated Toilet Bowl - 6145.223.02 Questions & Answers
Seth Thomas wall clock doesn't chime on the quarter, half or three quarter hour but does chime on the hour
Please change the time of your wall clock back 1 hour and check if the other 3 chimes return. There should be knobs on the side of the clock to help you do this. If not on the side, then please check on the back. Since you've already checked the settings and ruled them out as the cause of the issue (as well as the batteries), you might need to perform a factory reset on the clock if the steps I mentioned above fail.
Thank you.
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
