20 Most Recent KitchenAid KWVU205SS Kitchen Hood Questions & Answers
KitchenAid KGSS907SSS00 Oven. After self cleaning the oven I get error code F3E3 about the meat probe.
Question edited for clarity and add Maker. Question moved to maker category. Number 1 Tip, never ever use the self cleaning feature. It only exists to break the appliance and create the need for parts and service calls. The temperature is just too intense for the parts. A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use of any chemical agents. The oven can be powered by domestic (non-commercial) electricity or gas.
Why You should Never Run A Self Clean Oven Cycle & ...
General Appliance Service https://www.generalappliancesvc.com > why-you-shou... Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ... -------------------------------------------------------------------------------------- The only thing suggested is doing a power cycle, but the heat has probably fried the control board which is located too close to the oven and all that heat. https://www.google.com/search?q=KitchenAid+KGSS907SSS00+F3+E3+Error ..
10/5/2023 2:00:27 AM • KitchenAid... • Answered on Oct 05, 2023
KitchenAid Stove KERS205TSS 2 light issues.
The issue with the oven display light and the oven light on the KitchenAid Stove KERS205TSS 2 may be related. The problem with the oven display light could be due to a faulty control board or a malfunctioning light switch. The control board may need to be replaced if it is not sending a continuous signal to keep the light on. On the other hand, if the light switch is defective, it may not be able to maintain a connection to keep the light on. The issue with the oven light staying on could also be due to a faulty light switch. If the switch is stuck in the "on" position, it will not turn off even when the door is closed. This can cause the bulb to burn out prematurely and waste energy. To fix this issue, you may need to replace the light switch. It is possible that both issues are related and caused by a malfunctioning control board. If this is the case, replacing the control board should fix both problems. To fix these issues, it is recommended to contact a certified technician or an authorized service center for KitchenAid appliances. They will have the expertise and tools necessary to diagnose and repair the stove safely and effectively.
6/21/2023 7:50:53 PM • KitchenAid... • Answered on Jun 21, 2023
Gas range will not light. How can I get the oven to light?
The switch that makes it spark?
1/26/2022 5:45:16 PM • KitchenAid... • Answered on Jan 26, 2022
We can not power our Kitchenaid oven off. We unplugged and plugged it back in and got a display of a red 04 on top and in blue underneath AM71 UI71 EEKGO-010. Please advise
We are FIXYA dot com, we aren't Kitchen Aid. You error needs a service call, because it probably needs a new control board. These aren't cheap so it needs professional diagnosis. https://www.google.com/search?q=AM71+UI71+EEKGO-010+error+04 ..
1/18/2022 4:26:39 PM • KitchenAid... • Answered on Jan 18, 2022
20 year old KitchenAid oven KEBC107KSS0 broiler turned on by itself and would not turn off.
Age-related control failure
12/26/2020 5:55:30 PM • KitchenAid... • Answered on Dec 26, 2020
My kitchenaid range model number KESC307BALOO is showing an error message 5A 66
That is probably the SAbb code; the Sabbath mode has been set. This mode allows you to heat a meal while fulfilling the "no work" requirement for strict observance of the Sabbath. The oven will stay at the programmed temperature until you change the temperature or end the Sabbath mode. To end the Sabbath mode, open the oven door and press and hold 6 for 5+ seconds. Then close the oven door. Searching Kitchenaid's support site, https://www.kitchenaid.com/service-and-support/manuals.html , I found the manual for the KESC307 ranges here: https://www.kitchenaid.com/content/kitchenaid/en_us/searchresult.html?term=KESC307&tab=clp&plp=&plpView=grid&clp=kesc307 . The direct link to the manual is https://www.kitchenaid.com/content/dam/global/documents/200308/owners-manual-9754287-RevC.pdf . See page 18-19 for the information on the Sabbath mode. You can completely disable the option on the range by following the steps in the manual. I hope this helps. Cindy Wells
8/26/2020 10:31:48 PM • KitchenAid... • Answered on Aug 26, 2020
2answers
KitchenAid electric stove top ALL OFF/CONTROL LOCK will not turn off with depressing the button. Purchased December 2003.
Try unplugging for 15 minutes. Then plug back in. That may reset the board. If not, control Board is bad
12/10/2019 3:24:09 AM • KitchenAid... • Answered on Dec 10, 2019
I need a manual for a KitchenAid Superba Electric range model # KESH307HBS4 could you please help?
I didn't see an operator manual using https://www.google.com There were several diagrams and parts lists. An installation manual and a toll free number to call for support is at the link below: https://www.partselect.com/Models/KESH307HBS4/
10/4/2019 12:01:41 AM • KitchenAid... • Answered on Oct 04, 2019
Kitchenaid superba oven has error code F1 E4 door closed but door is open.What is cause & how can it be corrected.
Have you unplugged the appliance I reset it see if that clears it
9/15/2019 12:43:31 AM • KitchenAid... • Answered on Sep 15, 2019
How do I turn of the blue C on my KitchenAid Hood Fan. I have cleaned the filters.
Same here. I am in trouble like that. Need to find a solution! Best, http://giaydankinhgiahuy.com/
9/7/2019 8:48:08 AM • KitchenAid... • Answered on Sep 07, 2019
tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes. 4 Digit Failure Codes F1 - E0 EEPROM communication error F1 - E1 EEPROM checksum error F1 - E2 UL A/D error F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match stored value F2 - E0 Shorted touch pad F2 - E1 Keypad cable connection error F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models) F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models) F3 - E2 Oven temperature is too high (Cook mode) F3 - E3 Oven temperature is too high (Clean mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models) F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models) F3 - E6 Drawer sensor open F3 - E7 Warming drawer sensor shorted F4 - E1 Meat probe malfunction - shorted F5 - E0 Door Switch F5 - E1 Self clean latch will not lock F5 - E2 Latch during CLEAN error F5 - E5 Self clean temperature not reached within 45 minutes. F5 - E6 Door is open, but latch is locked F5 - E7 Self clean latch will not unlock F6 - E0 Return line not connected F7 - E1 Common switch wire defective Two digit codes: F0 ERC Board failure F1 ERC Board failure F2 Oven temperature is too high F3 Oven temperature sensor open F4 Oven temperature sensor shorted F5 ERC Board failure F7 Function key stuck on ERC F8 ERC Board failure F9 Oven door lock failure Microwave and Microwave combo error codes: F1 - E3 or F1 - E4 Electronic control malfunction F2 - E0 or F2 - E1 Keypad connection error F2 - E3 Keypad held down too long, or keypad is shorted. If you get an error code, try first resetting the code: 1. Disconnect power for about two minutes. 2. Connect back power. 3. If code re-appears, test and eventually replace faulty part.
on Aug 07, 2019 • Kitchen Ranges
My oven has stopped working. When I touch the touch pad nothing happens. Why is the digital readout displaying F2E1?
Good Morning, An E1-f2 E1F2 error indicates a faulty touchpad. Fixyourboard.com offers replacement Ledgestone Technologies touchpads for Kitchenaid oven models. Reach out to them for more information 512-355-1108 or [email protected] kp1b1705a3-crjxtk2pui4xc5qqbhljddcq-4-0.jpg ledgestone ka keypad-crjxtk2pui4xc5qqbhljddcq-4-2.png
6/19/2019 3:09:10 PM • KitchenAid... • Answered on Jun 19, 2019
KitchenAid KVWB606DSS hood vent my auto fan light just started blinking on and off a week ago. i can't find any info on whats wrong
here is the manual. If it is an LED bulb it may be bad. LED's tend to blink constantly when bad. https://manualsbrain.com/en/manuals/908701/
2/10/2019 7:49:20 PM • KitchenAid... • Answered on Feb 10, 2019
Have an electric KitchenAid KERA807: One of the glass top heat controls lights, but the light blinks and the "burner" does not heat. Why?
Odds are that element is bad and needs replaced some minor testing needs to be done to know for sure. I have attached a picture of the elements as they are different depending on position. #12 is the part. Sears parts direct can get you the part numbers. cooktop-eh5jesptcuvogop024kl2gvy-2-0.png
2/9/2019 6:00:02 PM • KitchenAid... • Answered on Feb 09, 2019
I just got a new house with new kitchen aid stove and over the stove microwave. Problem is the handle and circuit board get so hot you can’t Touch them?? What can I do???
Have you tried running the exhaust fan when using the stove? Also you might try using the back burners. It sounds like the microwave is sitting too low and this may cause more issues as the time goes on.
2/9/2019 5:19:12 PM • KitchenAid... • Answered on Feb 09, 2019
Kitchen Ranges Logo
0 questions posted
Top KitchenAid Kitchen Ranges Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Kitchen Ranges
Most Popular Question
kitchenaid stove kers205tss 2 light
  • Kitchen Ranges
