20 Most Recent American Standard 4112.016 Cadet Toilet Tank, Spring Questions & Answers
My toilet is double flushing. How can this be
can you call anybody?
9/10/2009 1:28:18 AM • American... • Answered on Sep 10, 2009
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM • American... • Answered on Feb 22, 2023
We have an American Standard 4035 elongated toilet. We want the water level in the toilet to be higher.
To make the water level higher in the pan, the outlet pipe must be higher.
6/29/2022 6:47:32 AM • American... • Answered on Jun 29, 2022
I have an American Standard 4035 dual flush toilet. How do I increase the water level in the bowl ?
Adjust the float on the fill valve
8/23/2021 10:14:08 PM • American... • Answered on Aug 23, 2021
Our American standard duel toilet takes to long to refill the tank and sometimes there is not enough water to flush just water down
Depends how old your toilet is, it may be a calcium build up problem on your little inlet pipe inside your tank, but first check your water shut off valve on left side of your toilet near the wall....It may not be open all the way OR the valve has an issue...
7/12/2019 11:28:54 PM • American... • Answered on Jul 12, 2019
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM • American... • Answered on Jul 12, 2019
We have a wall mounted American Standard toilet from the 1970's. The tank has a crack in it. Is it possible to just change out the tank?
Hi, First, carefully remove your tank lid, and place it where it won't break or fall. Look for a four-digit number located on the back of the tank, near the water level mark. This is your tank model number. If the number starts with a two, it is a one-piece toilet. Then....visit this link: https://www.americanstandard-us.com/parts-support/faqs/toilets Good Luck!
5/6/2019 8:23:04 PM • American... • Answered on May 06, 2019
American standard hands free toilet battery pack doesn't work
More likely the sensor has malfunctioned.
11/24/2018 6:54:16 PM • American... • Answered on Nov 24, 2018
American Standard 4061 toilet. Can periodically hear the toilet refilling when not in use. No visible issues. Replaced the flapper. Leak remains. No visible cracks on drain tube or tank.
these are called phantom flushes. the water is slowly leaking around flapper or the is a scratch of the flapper seat. I use fluidmaster parts
11/12/2018 2:22:42 AM • American... • Answered on Nov 12, 2018
How do fix my American standard cadet 3 toilet?
Toilets wear out from mineral deposits. Fixn may cost more then new. Googl used commodes first
11/4/2018 9:08:15 PM • American... • Answered on Nov 04, 2018
American Standard toilet tank won't refill.
Water turned off or fill valve bad.
8/29/2018 9:15:28 PM • American... • Answered on Aug 29, 2018
How to Clean # 3142 Toilet fill valve
I think it's not a wise decision to clean a toilet fill valve, rather than buy a new toilet fill valve and replace with the old one. Thanks.
6/8/2018 9:08:29 AM • American... • Answered on Jun 08, 2018
I have American Standard Absolute whirlpool jacuzzi. It won't run, when I plug it in, it pops the breaker. UltraJet 2 speed pump Emerson 2 H.P 115v, 60-1. Could there be a reset on the motor itself?
no reset on motor ( that would not cause breaker to trip, suspect heating element, or motor is bad.
5/2/2018 6:48:15 PM • American... • Answered on May 02, 2018
American Standard 4112.016 Cadet Toilet Tank, Spring Logo
Popular Tags
1 questions posted
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Home
Most Popular Question
toilet double flushing
  • Home
