20 Most Recent Ativa At-p6000 Desktop Printing Calculator Questions & Answers
Is sounds like you have a paper jam. Most jams are pretty much the same. First, try running the blades in REVERSE, that is done by using the on/off, selector switch.
If that does not solve the problem, Unplug the unit from the electrical, remove the top part from the basket. Pull out as much of the paper from the top and bottom that you can.
Replace the unit on the basket (make sure it is facing in the correct direction) and squirt, or lightly pour mineral oil (or machine oil, or something like WD-40) directly on the rollers and let it absorb into the remaining paper for a few minutes then try running the unit. If the motor does not come on, there is a fuse inside the machine that may need to be replaced.
Once you have solved the problem, you should oil the blades after every hour of use, it really makes it easier on the blades.
Also, there is an internal "heat switch" in the machine that will shut it down for about 90 minutes if the motor gets to hot. It is a safety factor in case you get something stuck, like a person wearing a tie, etc. After the machine has cooled down, turn the on/off switch to off and then back to on.
If that does not work, try their Customer Service at:
http://www.ativaproducts.com/contact.html
Ativa Office... | Answered on Jul 19, 2014
Typically this means the device is overheating. Check if the fans are doing their job and if any filters / air intakes need cleaning.
Office Equipment... | Answered 15 hours ago
This error is related to the rear cooling fan.
Physical inspection required, if not capable of doing it yourself please call a certified technician.
Definition of check engine code P1622:
BMW:
Map Cooling Thermostat Control Circuit Electrical
Chrysler/Dodge/Jeep:
5V Output Reference Voltage 2
Citroen/Peugeot:
Immobilizer ID Does Not Match
Daewoo:
A/C CONTROL CIRCUIT MAL
Ford:
GM:
Cylinder Select
Jaguar:
Engine control module engine immobilization input code malfunction
Land Rover:
Repeated Wrong ECM Security Code Fault
Mazda:
lmmobilizer System Fault
Mercedes:
Electrohydraulic shut - off actutor (Y1/1)
Opel:
Fuel pump relay
Saab:
A/C Relay, Output Form Control Module High
Volkswagen/Audi:
Engine coolant temperature signal range / performance
Volvo:
Office Equipment... | Answered Yesterday
ON THE TAX WEBSITE
Office Equipment... | Answered 2 days ago
https://www.youtube.com/watch?v=EdQBuzDFGnI
Office Equipment... | Answered 3 days ago
You can take help from a brochure printing company that would provide you best attractive designed brochures for your business or service.
I can suggest you best template collection that you can use as a base template or for inspiration.
Brochure Templates PSD would provide you a wide range of templates which is designed carefully with best fonts, colors, and layouts.
Ativa At-p6000 Desktop Printing Calculator Logo
Popular Tags
3 questions posted
Top Ativa Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you an Ativa Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ativa Office Equipment & Supplies
Most Popular Question
ativa shredder model md 1250 became
  • Office Equipment & Supplies
