A Square D QOABB is a QO style circuit breaker, as determined by the "QO". A represents the number of poles; and can be 1, 2 or 3. This number also represent the number of spaces it requires in the panel (NOT the cover). "BB" represents the Amp rating of the handle. Common values are 15, 20, 30, 40, 50, 60, and beyond. A Square D QO3100 (3Pole 100A) is pictured below:
A Square D QOTXXYY is a tandem circuit breaker. "T" represents Tandem. "XX" is the amp rating of one handle and "YY" is the amp rating of the second handle. It occupies one singe slot in the panel (again, NOT the cover). It look like this QOT2020 (A single pole breaker with tandem 20 amp handles) below:
The clip under terminal screws engages the panel's "rail", and the other clip(s) must engage the panel's powered bus or "metal" strips as you called them. If you are installing a QO230, BOTH clips MUST engage. If only one engages, you will only have 120 Volts to ground, and may not be able to put the panel cover on. I hope this helps and good luck!
