20 Most Recent Luminox Navy SEAL Dive 3901 Wrist Watch Questions & Answers
I have a Luminox 3050/3950
Generally after two years power cell life will over.> are your replaced same battery? check the voltage of power cell _1.5V> Observe that seconds needle giving any jerks? if its trying to move its overhaul faulty, give it to good service center for overhaul.> If its not at all moving at all it might be coil or PCB faulty..
12/6/2011 9:28:17 AM • Luminox Navy... • Answered on Dec 06, 2011
2answers
Needs battery. do we get
Thank you for contacting FixYa.
You will need to find a local repair shop that can reseal after putting in new battery, or send to :
http://www.luminoxshop.com/luminox-repairs.html
Best regards. Jewel
9/9/2010 1:49:37 AM • Luminox Navy... • Answered on Sep 09, 2010
Arm on the case broke off
mcdevito75 here, I hope you have a warantee with the watch, even if you don"t contact Luminox watch with this problem, Hold onto that broken piece off the watch. Problem is the case is 1 solid piece, the watch company will want to see the broken case and piece offf the watch, hopefully they might figire a defect in the case cause the piece to break off and replace the case for you for FREE, I doubt it BUT, you never know.
6/30/2010 1:20:13 AM • Luminox Navy... • Answered on Jun 30, 2010
Need new bezel
Try parsecent.com, you can get a replacement bezel there...
and you are right, you are basically buying a new watch as this model is made of plastic and cannot be 'polished'. Refurbishing it means that it will look new and everything on the outside would have to be replaced...good luck :)
11/18/2009 8:57:28 PM • Luminox Navy... • Answered on Nov 18, 2009
Do I have to wind the watch after I replace the
No you don't have to wind this watch..it is a quartz movement powered by a battery...the only thing the crown is used for is resetting the time and date, you are probably thinking of a mechanical watch which is powered by a mainspring...:)
11/18/2009 8:53:49 PM • Luminox Navy... • Answered on Nov 18, 2009
3903 Blue Faced Seal Dive watch Bezel
best bet is to contact luminox...i had to do it for mine. Even if it was a purchase from a third party, they may take care of it for free...
8/14/2009 9:31:58 PM • Luminox Navy... • Answered on Aug 14, 2009
Luminox bezel
Grab the knurled edge of the bezel and turn counter clockwise. It only moves in one direction- to the left, counter clockwise.
3/14/2009 8:06:16 PM • Luminox Navy... • Answered on Mar 14, 2009
My 2nd hand is stuck at the nine o'clock position. It moves but does not advance just returns to nine. I recently changed the batter which worked well for about 10 hrs.
The hand in question is slipping on the spindle that it is attached to. You need to carefully but firmly push it back down on the spindle so it moves. Have to get access to the dial and needles to do this
8/30/2015 3:11:13 PM • Luminox Seal... • Answered on Aug 30, 2015
Luminox navy seal watch skipping second hand by 5 seconds still keeping perfect time, changed battery after testing (shows 1.5 v) still skipping. what could be wrong
a mechanical part needs replacing, unless your have some form of funky split time running? replacing the battery should have reset it though.
2/1/2021 12:56:43 AM • Luminox Watches • Answered on Feb 01, 2021
How much to repair the stem and crown on a navy seal blackout luminox watch? A child pulled the crown out too hard and it won’t adjust the hour hand.
take it to a watch maker for a quote and to see if the parts are available
5/8/2018 5:58:53 AM • Luminox Watches • Answered on May 08, 2018
0answers
Luminox Navy SEAL Dive 3901 Wrist Watch Logo
9 questions posted
Top Luminox Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Luminox Watch Expert? Answer questions, earn points and help others
View Most Popular
Seal Luminox
  • Seal Luminox
Most Popular Question
wind watch after replace
  • Watches
