20 Most Recent Krups Caffe Bistro 867 Espresso & Coffee Maker Questions & Answers
check inside for broken or burnt connectors going to the heater element. these are normally slide in spade connectors.
Krups Caffe... | Answered on Sep 07, 2018
Decalcify the water holder. Run some CLR and water thru the brew cycle.
Krups Caffe... | Answered on Jan 20, 2015
Notice the pot. It holds 12 Canadian cups or 6 mugs of coffee. The sides of the pot are straight and the pot is calibrated in cups although you cannot see the calibrations in this photo.
They are drip machines that all brew coffee the same way. You put the coffee in the basket and cold water in the tank. The machine brings the coffee to the basket but boils it on the way to the basket. Therefore the coffee is always the same. They all have the feature that lets you pull the pot out safely while it is still brewing. That is great if you can't wait for the machine to finish brewing all the coffee.
Krups Caffe... | Answered on Mar 03, 2013
There is an overheating safety fusible link under the hot plate. It is probably burnt open.
murf427
Krups Caffe... | Answered on Oct 19, 2012
we dont understand your question pls elaborate further. thanks.
Krups Caffe... | Answered on Oct 18, 2012
There is an overheat protection link under the hotplate. It is probably burnt open. murf427
Krups Caffe... | Answered on Aug 01, 2012
I'LL BE HAPPY TO PROVIDE YOU WITH THE ANSWER JUST AS SOON AS YOU PROVIDE ME WITH YOUR BILLING INFORMATION AND AGREE TO MY TERMS AND CONDITIONS.
Krups Caffe... | Answered on Jun 23, 2012
This indicates the problem of flow meter was not working. The flow meter is located between the water tank and the pump.
This is procedure how to test if flow meter is cause: Open coffee machine and pull out flow meter (do not disconnect it, just unscrew it from housing), prepare any magnet (neodimium magnet if possible), press the button to start making coffee. Coffee machine will start, then stop for a second, then start again. When it starts again put magnet close to flow meter's contacts and then move the magnet away and keep repeating that moves very fast. If coffee machine is working fine then you have to replace flow meter.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Krups Caffe... | Answered on Oct 20, 2010
Krups Caffe Bistro 867 Espresso & Coffee Maker Logo
53 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Ross Keen
Steve Allison
Steve Allison
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
not brew coffee hot plate cold
  • Coffee Makers & Espresso Machines
