20 Most Recent Krups GVX1 Electric Burr Grinder Questions & Answers
Remove grind selector and # of cups dials, just pull it off. The grind selector dial has a spring loaded detent, the spring will come loose, try not to lose it as well as the detent "plunger" (the piece that engages the dial detents).
The outer housing can slide off the inner chassis, there are four detents located in the vicinity of the four foot pads, use something like a small screwdriver to pry apart the inner and outer plastic parts and pull apart. You may have to loosen one corner at a time, when the last detent releases the outer housing slides up and off easily.
Krups GVX1... | Answered on Aug 03, 2015
If you can't figure out how to diss-assemble the device yourself, I recommend that you take it to a proper service shop, making sure you call a few of them in your area and find out if they charge for inspection and estimates of repair, then see which one has the best estimate.
Krups GVX1... | Answered on May 17, 2015
Sounds as if you may have had a spill of something sticky in the switch. Try taking the switch out and cleaning it.
Krups GVX1... | Answered on Feb 20, 2011
With the top sensor- I found with mine the pin was missing that actuated the top cover switch in th fill area right side you'll see a small pin hole. All I did was remove the side cover and jump out the switch via solder connection. The side cover has (4) click locks on the bottom that hold it on then it slides up and off. I know its a safety switch but it was more of a pain than a help.
Krups GVX1... | Answered on Jan 29, 2011
I have a dolce gusto and i am unable to remove the coffee capsule. It seems stuck, as does the lever that punctures the capsule. If the valve lever is moved right or left nothing comes out. Please can you help?
Krups Coffee... | Answered on May 20, 2019
Error 12 There was no pulse from the ejection switch so possibly a switch problem or worse still some grief on the control PCB. This will also be associated with the cleaning the drawer problem. From memory the switch/es are located above the used grounds bin.
Krups Coffee... | Answered on May 07, 2019
Krups GVX1 Electric Burr Grinder Logo
Popular Tags
16 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
disassemble gvx1 burr
  • Coffee Makers & Espresso Machines
