20 Most Recent Intermatic T104R 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw Questions & Answers
most cases pump motors are 230 v. must check w meter set at around 700 v ac. 130 + 130 doesn't make 230 . check the two lines at the breaker and work your wak back to the motor. how to voltage test a breaker how to voltage test breaker Google Search
Intermatic T104R... | Answered on Dec 02, 2017
The contacts inside the time clock have most likely warn out. If it is coming on randomly it is not making good contact and will create arcing, which is dangerous. Call an electrician, they may be able to replace just the internals.
Intermatic T104R... | Answered on Aug 20, 2016
If you are getting voltage to the motor, and it still doens't work, you probably need to replace the unit.
Intermatic T104R... | Answered on Aug 08, 2014
You need to check the line voltage being supplied to the timer. It is possible that you have a reversed neutral and common (hot) line providing power to the timer. It is also possible to have another reverse situation with the way the timer is hooked up to the device it is controlling.
Timer motors should only operate in one direction, but if mis-wired, they can operate backwards.
I would need more information about the exact installation you have in order to provide a more thorough diagnois and solution. Info such as is this a 220V-AC installation; is the timer hooked to more than one (1) device (pump, etc.) ; Is there a GFCI breaker on this circuit (there should be!) ; Is this a new installation or a refurbished pool with a new pump & timer?
Please use the "comment" button to supply me with the info requested so I can better address your issue.
Thanks!
Intermatic T104R... | Answered on Jul 28, 2014
Wiring is wrong:
Copy following links for illustrations and resources:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
What switch did you replace?
Add a comment and describe problem with switch???
Gene.
ll
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Intermatic T104R... | Answered on Sep 15, 2013
T104 timer is 240Volts.
Not 120Volt
You can convert timer into 120V by changing clock motor from WG1573 to WG1570. This action will convert the T104 into T103.
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
The T104 timer can be wired many different ways:
Copy following link for illustrations showing both T104 and T103 wiring
Add a comment with specifically what you are connecting to timer, and I will comment back with more detail as needed.
Intermatic T104R... | Answered on Oct 08, 2012
The problem is that you need a jumper wire to power the clock from one of your two hot wires (assuming the clock is 120V), because the clock is currently powered downstream from the switch built into the timer. The jumper wire needs to go from one of your hot wire inputs to the clock. Don't add a new wire, just move the existing jumper wire that is going from one of the output terminals to the clock, so that it goes from one of the input terminals to the clock.
Intermatic T104R... | Answered on Jul 29, 2012
Your 240V wiring is not described clearly, and it sounds like you are confused about 240Volt circuits.
You posted under T104R indoor-outdoor 240volt timer:
Typically a 240Volt cable is 2-wire with ground, and does not have a 'neutral'
A neutral is not necessary to complete 240V circuit.
If your 240Volt cable is a 3-wire with ground, then the neutral connects to terminal A on timer.
Open following links for specific T104 wiring diagrams plus illustration of 2-wire and 3-wire cables, and illustrations and explanation of difference between 120V and 240V circuits:
http://waterheatertimer.org/images/wire-ga-250.jpg
http://waterheatertimer.org/B220C.html
If you have 240Volt cable, then do not move clock motor wires.
The clock motor wires connect to terminals 1 and 3.
240V power from circuit breaker connects to same terminals.
Load wires connect to terminals 2 and 4.
If you are not getting 240V across terminals 1 and 3, then check circuit breaker.
240Volt circuit breaker can be tripped off on one leg, or bad on one side so you get 120V on one leg at timer, and then clock motor does not rotate dial.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Intermatic T104R... | Answered on Sep 28, 2011
Posted under Intermatic T100 series timer:
Open following link for troubleshoot and to identify replacement parts:
If this is not your timer, then add a comment with model number or description of timer for possible help.
Intermatic T104R... | Answered on Aug 06, 2011
Is the clock keeping time?
Was a new clock installed so that wiring was disturbed?
Ensure that it is wired to the line on terminals A & 1.
If the clock is operating, is the ON tripper installed properly, that is, hitting the switch to turn on
the load?
Do you have the proper tripper for your timer?
These are some areas that can be inspected.
Gary
Intermatic T104R... | Answered on Jul 28, 2011
You can purchase Stops from HERE
Intermatic T104R... | Answered on Jun 26, 2011
Two hot wires from the panel go to "line" and two wires from motor go to "load". See the diagram on the inside of the door. You should consider running the "load" to a 220 wall switch and then to the motor so you can turn it off quickly if necessary without fooling with the timer.
Intermatic T104R... | Answered on May 30, 2011
The clock motor has gotten weak.
With Intermatic T100 series timers, replace WG170 120Volt or WG1573 240Volt clock motor for $20.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Intermatic T104R... | Answered on May 24, 2011
The trippers can be obtained here:
http://www.aplussupply.com/intermatic/timer.htm
Scroll down just a bit.
Intermatic T104R... | Answered on Feb 23, 2011
Couple of possibilities
1. make sure the clock motor is connected to the input line 2. see #1, but make sure the clock motor comes before the switch (so it's not running just when the switch is "ON")
3. ... and make sure the feed is always on
Intermatic T104R... | Answered on Feb 16, 2011
Did you forget to push the yellow dial back in? If the timer has been in place for a while and was working OK in the past, this tip may help:
http://www.fixya.com/support/r4722277-troubleshoot_problems_intermatic_timers_
If this is a new installation the timer is mis-wired. The incoming 240 volt wires from the circuit breaker (or source) _must_ be connected to terminals 1 and 3 because the clock motor is also connected internally to those terminals. Read this tip:
http://www.fixya.com/support/r3734548-wire_intermatic_t103_t104_timers
Intermatic T104R... | Answered on Dec 11, 2010
Intermatic T104R 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw Logo
46 questions posted
Top Intermatic Electrical Supplies Experts
Gene Haynes
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Intermatic Electrical Supplies
Most Popular Question
replaced intermatic t104 timer but clock
  • Electrical Supplies
