20 Most Recent
GE 50 gal. Heat Pump Electric Water Heater Questions & Answers
New thermocouple on GE/rheem water heater pilot still won't lite
does the pilot go out when you let off the button? Or does the pilot not light at all? If you dont get any gas at all to the pilot the the gas valve is bad.Of you get a pilot light that goes out when you let go of the button then the therno couple is not reading the flame (needs adjustment so the pilot flame touches it) did you kink the new thermocouple? or over tighten it at the gas valve.if it was kinked its now toast,cant straighten them. If kinked and starightened the fluid inside has broken the inner seal and wont work.
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock.
Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
