20 Most Recent Ridgid Vacuum. 12-Gal. 5 PHP Wet/Dry Vac WD1270 Questions & Answers
Check contiuity on the switch.
Ridgid Vacuum.... | Answered on Jun 01, 2014
if you got if from supa cheap , they will organize the replacement parts
anywhere else , contact the service agent
Ridgid Vacuums | Answered on Nov 09, 2017
before replacing the motor, check the switch itself,, it could be bad or shorting ,, also,, if it seems intermittent it could simply be the motor brushes are worn, both of those are much cheaper than the motor, as with many fixes, sometimes its cheaper to replace the whole thing that repair it,, especially with vacuums
Ridgid Vacuums | Answered on Mar 25, 2016
Hi Linda: It sounds as if you may have sucked up something that has not passed through the hose to the dust collection canister. This would explain the overloading of the machine and the shutdown.
As a next step you will need to check to make sure that the nozzle, hose and the connection to the dust collector is not plugged or partially plugged. Clear any obstruction and this should correct the problem.
If this does not resolve your issue, please reply with additional information. What type of material were you vacuuming? Was there any physical damage to the filter?
Thank you for using FixYa!
Ridgid Vacuums | Answered on Nov 18, 2011
Hi There and Welcome to Fixya.
As a technician, if a certain electronic appliance had a 'burning'(or anything close) smell then there's a great chance that a minor short circuit occurred within the internal electronic boards. With this, I am highly recommending for this to be serviced unless you are a certified/trained technician that can perform the necessary repairs. And to answer your question, there are no "rest" or "hibernate" button on this machine.
For you to double check if you're missing something, here's the link for the user's manual as well as repair options :
RidGid Support
Thanks for using Fixya.
Ridgid Vacuums | Answered on May 05, 2011
I have a shop Vac too. It will only pick up when held at the surface rather than completely submerged.
Ridgid Vacuums | Answered on Sep 30, 2009
Ridgid Vacuum. 12-Gal. 5 PHP Wet/Dry Vac WD1270 Logo
3 questions posted
Top Ridgid Vacuums Experts
John Powell
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Ridgid Vacuums
  • Ridgid Vacuums
Most Popular Question
vac won 39 t turn
  • Vacuums
