20 Most Recent Frigidaire Affinity FAHE4044MW 27" Top-Load Washer with 3.4 cu. ft. Capacity, 14 Wash Cycles, 2 Specialty Cycles, 800 RPM Spin Speed, WaterFall Wash, Fresh Water Rinse and Energy Saver Option Questions & Answers
Thank you for your inquiry, friend!
Based off the information you have provided your Frigidaire washer keeps filling with water then will spin out and shut off. This sounds like an issue with your water valve or control panel. I would recommend performing a reset on your washer and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does fix the issue you may want to have a professional technician out to perform a proper diagnosis. Hopefully this is helpful information. -Matt
Frigidaire... | Answered on Mar 12, 2015
Good Morning Friend,
I understand that you are receiving multiple error codes on your Frigidaire Affinity washer, model# FAHE4044MW. I see that the error codes showing are "E", "PA", "AU", "U5", and "5E". I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
WP
Frigidaire... | Answered on Jan 18, 2015
replace drain hose
Frigidaire... | Answered on Apr 14, 2014
I DON'T KNOW. CHECK ELECTRICAL OUTLET WORKS.
UNPLUG AND PLUG CORD BACK IN OUTLET. OPEN AND CLOSE DOOR A FEW TIMES TO ENSURE DOOR CLOSES PROPERLY. . PUSH 'STOP/PAUSE' TWICE. CHOOSE 'RINSE/SPIN' . CHOOSE 'HIGH SPIN'. PUSH START. THIS MAY RESET WASHERS PROGRAMS. NOT LIKELY BUT 'DELAYSTART' MAY BE ACTIVEATED..
Frigidaire... | Answered on May 18, 2019
The Frigidaire GLTF1240A clothes washer has a tub capacity of 2.65 cubic feet. Under typical conditions, based on a yearly average of 392 loads of laundry, the Frigidaire GLTF1240A is estimated to use 341 kilowatts of energy per year. Obviously, this number will vary depending on things like the size of loads that you wash, and temperature at which you wash your clothes. Also, this figure is calculated according to a test done by the US Department of Energy which takes into account the energy consumed by the washer as well as the energy needed to heat the water with an electric water heater. If you use a gas water heater you will probably use fewer kilowatt hours but you will consume gas to heat the water.
Its estimated water use is 9,806 of gallons per year. It is estimated to use 9.4 gallons per cycle, per cubic foot of tub volume. You can use this "per cycle, per cubic foot" to compare washers against each other. The lower the number, the more efficiently the washing machine uses water, assuming your clothes are equally clean after being washed in either washing machine.
Frigidaire... | Answered on May 08, 2019
Frigidaire Affinity FAHE4044MW 27" Top-Load Washer with 3.4 cu. ft. Capacity, 14 Wash Cycles, 2 Specialty Cycles, 800 RPM Spin Speed, WaterFall Wash, Fresh Water Rinse and Energy Saver Option Logo
Popular Tags
11 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
washer keeps filling up water will spin
  • Washing Machines
