20 Most Recent
Kohler K-3497 Cimarron Comfort Height Two-Piece Round Front Toilet, Left-Ha Questions & Answers
My kolher k3497 will not hold water in the bowl.
It depends on what you mean "not used daily".
I am discounting any possible cracks.
If you only see this after a month or so, the water just evaporates.
If the water level in the bowl drops more often, the different pressure could cause it to exit the normal way. You could try opening and closing a few doors while watching if the water moves at all.
You can have someone flush the 'regular' toilet while you watch the water in the bowl of your guest toilet. There should be no movement at all.
If none of this gives any indications, I guess a plumber might know after inspecting it.
When flushed, not enough water coming from bowl
Its simple. Check to see if you installed toliet right by removing top of tank and holding handle all the way down. Did it flush from all rim holes? If not, then u will need to get a garden hose with a sprayer to increase pressure and shot high volocity water at rim holes to unblock it. Remember the very front on newer blows do not have holes its a pee shield. Also try doing these other things adjust screw inside tank to make sure the bowl has enough water in it to do a good job. Check the rubber tube going into the hollow pipe and make sure it is going fully inside the plastic pipe that is sticking out of the top of the water in the tank. Also you need to have enough water in tank to allow it to flush good. To increase tank water levels then just unscrew the big plastic ball (or just bend wire to allow more water or bend to allow less water) at top of water in tank. Also increase (max) water pressure at wall to allow it to work at its best. If you have hard water it can cause problems but you say it happened even new, so, you do not have to go in that direction.
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
