20 Most Recent Air Innovations Ultrasonic Digital Humidifer with Digital Display - - Questions & Answers
the inlet valve spring is too strong on these, so the water can stop flowing into the unit. makes sure it is on a flat surface, fiddle with the valve spring.
Air Innovations... | Answered on Dec 26, 2016
This is an indication that the power supply has issues. You would have to take it apart to check and see what is wrong.
Air Innovations... | Answered on Mar 10, 2015
Call the manufacturer with your information. They will more than likely need proof of purchase (your old receipt) and you will have to pay shipping if the warranty is still valid.
Air Innovations... | Answered on Dec 15, 2014
Hello... this humidifier uses timer? then, some humidity has damaged the circuitry. Try to disassemble as far as your skills permit; then put the unit outside of home in a place where the sun and wind can dry this device. And try to use destiled water if is not expensive in your area.
Air Innovations... | Answered on Aug 10, 2014
check makers website
Humidifiers | Answered 7 hours ago
fixya doesnt sell parts for anything
Humidifiers | Answered 2 days ago
After replacing the Water Panel, turn the control knob to the “Test/Reset” position until the “Change Water Panel” light blinks to reset the Water Panel change indicator timer.
Humidifiers | Answered on Apr 09, 2019
You need to check to make sure the condenser fan is blowing and that the condenser coil is clean. You absorb heat inside the refrigerator, compress that heat with the compressor, then expel the heat at the condenser (the part of the system that blows hot air). If you can't expel that heat, the unit will lock itself out until you reset it
Humidifiers | Answered on Mar 30, 2019
Air Innovations Ultrasonic Digital Humidifer with Digital Display - - Logo
8 questions posted
Top Air Innovations Humidifiers Experts
 alejandro
alejandro
Level 1 Expert
Tom Chichester
Are you an Air Innovations Humidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Air Innovations Humidifiers
Most Popular Question
humidifier making noise not steaming
  • Humidifiers
