If your Ryobi flexible shaft tool does not stop turning when you take your foot off the speed control pedal, there may be a problem with the speed control pedal or the tool itself.
Here are a few steps you can try to troubleshoot and resolve this issue:
- Check the speed control pedal to make sure it is functioning properly. Try pressing the pedal all the way down and releasing it several times to see if it is working correctly. If the pedal is not functioning properly, it may need to be replaced.
- Check the connections between the speed control pedal and the tool. Make sure the connections are secure and there are no loose wires or damaged components.
- Check the settings on the tool to make sure it is set to stop when the speed control pedal is released. Some tools have a setting that allows you to control the speed manually, rather than using the speed control pedal. Make sure this setting is not enabled on your tool.
- If the tool still does not stop when the speed control pedal is released, the problem may be with the tool itself. In this case, you may need to contact the manufacturer or a qualified repair technician for assistance.
Overall, if your Ryobi flexible shaft tool does not stop turning when you take your foot off the speed control pedal, there may be a problem with the pedal, the connections, the settings, or the tool itself. Follow the steps above to troubleshoot and resolve the issue.
