20 Most Recent Makita Bo4550 Finishing Sander Sanders Questions & Answers
It is insulated, if all your wet sanding will keep the sander motor out of the water I would but that is me. water and electricity don't mix.
More details
The Most Trusted Makita Palm Sander review
Makita Tools &... | Answered on Mar 15, 2018
Request the wiring diagram directly from Makita.
Makita Tools &... | Answered on Aug 31, 2017
This separator tool is neccesary to get the bearings from the armature the other parts have needle bearings and sinterbronze bearings , with a grinding machine its much more work to get them off And more chance of damage.
Makita Tools &... | Answered on Aug 10, 2017
My Makita router arrived with a couple of template guide bushes of different sizes. The size of guide bush chosen for use with a particular template will be dictated by the template - stock templates usually state the size of guide to be used with that template and mostly these are generally so common sizes a good router is supplied with them, from memory I think the smaller of my guides is something like 17 mm.
Template guide bushes are flimsy and easily damaged and so it is expected router users will be buying spares and other sizes. They are almost universal but not quite and router users are quite adept at minor modifications to make things fit, and not just guide bushes but also router tables, adaptors for various tasks and so forth.
I suggest you take a glance through a few catalogues featuring router accessories, including Makita of course.
Makita Tools &... | Answered on May 14, 2017
Its good that charger is made to fitted different types of dc voltage batteries thats the way of more or less voltage it is automatically measured by the used battery.
Makita Tools &... | Answered on Oct 12, 2016
could be a bad trigger switch
Makita Tools &... | Answered on Sep 17, 2016
Loose connection of power supply terminal inside the drill.
Remove the power suply chord.
Open the end cover , where th power supply cable is enetering the machine.
Check the terminals.
Remove the cable & re connect and tight properly
Makita Tools &... | Answered on Sep 08, 2016
Too much work for the money, buy a new one. If the bearings are shot, you got some hours on it..motor brushes are next and Probly soon.
Makita Tools &... | Answered on May 15, 2016
Makita Bo4550 Finishing Sander Sanders Logo
1 questions posted
Top Makita Tools & Hardware - Others Experts
Jim Thurston
Mike Squire
John Trevino
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Makita Tools & Hardware - Others
Most Popular Question
sander doesnt run full speed s slow ve
  • Tools & Hardware - Others
