20 Most Recent Whirlpool Caresse 2 Person Bathtub Seats Two Adults Questions & Answers
Need User Manual
Go to Jacuzzi.com and plug in model and serial no. you should be able to find an operation manual there.
8/19/2009 9:48:23 PM • Whirlpool... • Answered on Aug 19, 2009
How to clean jet on whirlpool tub
first of all you need to be draining the tub completely and removing any bath mats or items from inside. Fill the tub with hot water, ensuring that the jets are covered. You can use white vinegar, 2-3 cups of white vinegar directly to the water in the tub. Turn on the whirlpool system and run it for 15-20 minutes. While the jets are running, use a soft-bristled brush to scrub the jet openings and the interior walls of the tub. Drain the Tub: Refill the tub with clean water and run the jets again for another 10-15 minutes to rinse out any remaining cleaning solution. This should help. This is what I did with mine
4/10/2024 6:31:58 AM • Whirlpool Home • Answered on Apr 10, 2024
Is there anyone in Santa Fe, N.M. able to cap off and permanently seal the six jets on an older Lasco whirlpool type bathtub? And if so what would you charge for this? Thanks!
Didn't I answer this yesterday? I said a local plumber, a spa pool shop, fill them with silicone if you aren't going to use the jets again, or just replace the tub if it is leaking. We don't charge for anything. We are Fixya, we only supply information, nothing else. Fixya isn't really the place to ask for quotations. General plumbers https://www.google.com/search?q=santa+fe+nm+plumbers or specialist plumbers for spa baths https://www.google.com/search?q=santa+fe+nm+spa+bath+plumber ..
2/8/2024 11:06:42 PM • Whirlpool Home • Answered on Feb 08, 2024
Duracraft Plastics Schedule 40 bath drain in a Lyons plastic whirlpool corner tub; Foot Lok stopper will not go down; tried cleaning still cannot unscrew it to clean and clear blockage. Any ideas?
One of these? https://www.amazon.ca/Bath-Drain-Foot-Lock-Plastic/dp/B00L66HVWM Can't you get a drain snake down the side, or these are very effective for pulling long hair blockages and are flexible enough to easily go around corners. I use mine every 6 months. The Green Gobbler cleaner is also very good, or use Draino Gel. https://www.amazon.ca/dp/B00IJFU440/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B00IJFU440&pd_rd_w
Green Gobbler Dissolve Hair and Grease Clog Remover
Home Depot https://www.homedepot.ca > ... > Drain Cleaners Highly effective against grease, hair, soap, and fats. Green Gobbler Dissolve Drain Clog Remover is odourless, nonflammable, and safer to use than ... $18.98 ..
1/27/2024 12:40:21 AM • Whirlpool Home • Answered on Jan 27, 2024
Aquaglass whirlpool tub on/off toggle switch
There is help and videos in this link https://www.google.com/search?q=aquaglass+tub.+replace+toggle+switch If it is completely enclosed, a plumber will normally make an inspection panel from the other side of the wall to gain access. https://www.google.com/search?q=aquaglass+tub+installer ..
9/26/2023 5:17:26 PM • Whirlpool Home • Answered on Sep 26, 2023
I have a Pearl whirlpool tub. The motor stopped working without any warning signs. I'm realizing Pearl motors are no longer being made. I had an electrician check power and he said it was fine. Any suggestions as to what / where I go to resolve this??
every motor has a frame size and horsepower listed on it. search for a new one that way. i would think since its driving a pump it will need to be a totally enclosed/driproof model
11/10/2020 9:07:07 AM • Whirlpool Home • Answered on Nov 10, 2020
K-792-HE whirlpool tub pump powers on but no jets.
Did you turn the outer rings on the jets? They could be turned off. They are used to adjust the bubble flow, but also to turn them on or off.
1/20/2019 1:05:44 AM • Whirlpool Home • Answered on Jan 20, 2019
2answers
Galbocca tub with jets
You have some bacteria build up on the inside of your tubing of the tub.Try some cleaning solutions per directions on the bottle of tub cleaner made specifically for this situation.Cleaning Solutions US Parts Center
9/23/2018 6:21:51 AM • Whirlpool Home • Answered on Sep 23, 2018
Galbocca bathtub with jets
I have galbocca jet tub which is no longer working. I live in Lawton, ok. No one works on them here. Any suggestions?
9/21/2018 5:53:01 PM • Whirlpool Home • Answered on Sep 21, 2018
Hi i have a whirlpool bath but the on off button wont turn off
Check breaker and reset switch.
9/6/2018 2:08:50 PM • Whirlpool Home • Answered on Sep 06, 2018
I bought a home with an aqua glass whirlpool tub. It has a single twist on/off switch. When I turn it to the on position nothing happens.
no power motor seized up thermal overload button needs pressing in
6/7/2018 11:52:38 PM • Whirlpool Home • Answered on Jun 07, 2018
We have an Oasis whirlpool tub what is the best way to clean the water lines to the jets and the jets.
I would do it chemically with solution designed for the job. Or maybe just put vinegar in the water and let it circulate for a while and then replace the water.
9/4/2017 3:30:23 PM • Whirlpool Home • Answered on Sep 04, 2017
Whirlpool Caresse 2 Person  Bathtub Seats Two Adults Logo
2 questions posted
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Home
  • Whirlpool Home
Most Popular Question
need user manual
  • Home
