20 Most Recent
Whirlpool Aquatic Serenity 11 Tub Ai11air7240p Bathtub Questions & Answers
How to clean jet on whirlpool tub
first of all you need to be draining the tub completely and removing any bath mats or items from inside. Fill the tub with hot water, ensuring that the jets are covered. You can use white vinegar, 2-3 cups of white vinegar directly to the water in the tub. Turn on the whirlpool system and run it for 15-20 minutes. While the jets are running, use a soft-bristled brush to scrub the jet openings and the interior walls of the tub. Drain the Tub: Refill the tub with clean water and run the jets again for another 10-15 minutes to rinse out any remaining cleaning solution. This should help. This is what I did with mine
Galbocca tub with jets
You have some bacteria build up on the inside of your tubing of the tub.Try some cleaning solutions per directions on the bottle of tub cleaner made specifically for this situation.
Cleaning Solutions US Parts Center
Galbocca bathtub with jets
I have galbocca jet tub which is no longer working. I live in Lawton, ok. No one works on them here. Any suggestions?
