I also have the same problem with peeling paint. However, during the early am hours, I noticed that...
(More)
I also have the same problem with peeling paint. However, during the early am hours, I noticed that my microwave was on. Later it shut off by itself. Luckily, it didn't stay on for long otherwise my home could have burned down. I'm getting rid of this microwave and purchasing another.
My microwave is only 14 mts. old and it has begun to peel inside and to arc when I use it. I have...
(More)
My microwave is only 14 mts. old and it has begun to peel inside and to arc when I use it. I have stopped using it, of course, but I find it strange that my last microwave lasted for six years and this one only lasted for a little over a year..just long enough for the guarentee to be void. Do they plan it this way?
I have a Rival microwave/convection oven. I have nooperating instructions. Where on the internet can...
(More)
I have a Rival microwave/convection oven. I have nooperating instructions. Where on the internet can I view/print this information?
The microwave could be in "Demo Mode" - Check your owners manual. In Whirlpool/Kenmore models this is indicated by a lower case...
written by ptishkevich
If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor,
the rectifier diode.or the magnetron.
The...
written by ginko
A microwave not heating up is caused by one or more of the following -
1) Failed controller board (unlikely if you are getting a clock readout
and...
written by MrMark52
Problem: Totally dead oven.
Possible causes:
No power to outlet (blown fuse or tripped breaker or GFCI).
Blown main fuse - likely due...
written by sweet_rascal
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I...
written by UNCLEMOE
I was also told that I would have to pay a technician to come out to replace the interior light bulb in my Advantium speedcook microwave, but after...
written by kersti
What can go wrong
The most common problems occur in the microwave generating portion of the
system, though the controller can be blown by a...
Splatters of food from microwaving look bad, smell bad, and decrease the efficiency of your microwave. Fortunately, microwaves aren't hard to clean if...
by wikihow
