20 Most Recent Xerox Workcentre 7345 Printer, Copier, Scanner Questions & Answers
Return to Search Results
Solutions for : Fault Code 009-936: More Than One Consumable is End of Life Fault Related Fault Code: 009-936 Solutions ranked by relevance:
  1. Make Sure All Highlighted Supplies Are Replaced
Have you found what you are looking for? Yes
Not Yet
Please Help
Xerox Workcentre... | Answered on Jan 12, 2019
Goto the Xerox.com website.
Sorry,
Good luck.
Xerox Workcentre... | Answered on Jul 04, 2018
That error is an IOT video failure. It tries to reset itself, but if it doesn't you'll need to reload the software on the printer which requires the Xerox PWS Laptop.
Xerox Workcentre... | Answered on Dec 08, 2017
007-960 MSI Paper Mismatch 2
In the UI specified plain paper or thick index paper.
Try this link:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=399,E=0000000005965351572,K=3062,Sxi=1,Case=obj(47319)
Xerox Workcentre... | Answered on May 24, 2016
Are you sure the clear section is cleaned. The waste box may have a chip on it that tells the copier I am full, so vacuum iy out will not help. if you see a clear sectoin of plastic that has to be clear or the sensors will read the box as full. Replace the box, recommend always have a spare, so that during a print job if it come up replace the box and keep running. Another could be you are required to clear a counter every time you replace the box as long as the counter is not clear copier thinks the box is full. Go to Xerox web site contact them
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Xerox Workcentre... | Answered on May 07, 2016
Are you sure the clear section is cleaned. The waste box may have a chip on it that tells the copier I am full, so vacuum iy out will not help. if you see a clear sectoin of plastic that has to be clear or the sensors will read the box as full. Replace the box, recommend always have a spare, so that during a print job if it come up replace the box and keep running. Another could be you are required to clear a counter every time you replace the box as long as the counter is not clear copier thinks the box is full. Go to Xerox web site contact them.
That error indicates that the paper was not sensed as passing the pob sensor which is right at the registration rollers. If the paper is folding there, the main cause is the registration clutch not being initialized or slipping. Replace registration clutch, part number: 121K22220
http://www.iteminconline.com/121k22220_121k22220-xerox-7760-registration-clutch.htm
Xerox Workcentre... | Answered on Mar 28, 2016
Xerox Workcentre 7345 Printer, Copier, Scanner Logo
42 questions posted
Top Xerox Office Equipment & Supplies Experts
Michel
Clive
Clive
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
error code 004 363
  • Office Equipment & Supplies
