Sanyo STW1223H2 12000 BTU PTAC AC - Heat Pump With Backup of Electric Heat Air Conditioner
Problems with Sanyo STW1223H2 12000 BTU PTAC AC - Heat Pump With...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Sanyo STW1223H2 12000 BTU PTAC AC - Heat...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Sanyo STW1223H2 12000 BTU PTAC AC - Heat Pump With Backup of Electric Heat Air Conditioner RSS Feed
View More Results for Sanyo STW1223H2 12000 BTU PTAC AC - Heat Pump With Backup of Electric Heat Air Conditioner
Questions and Unsolved Support Problems
Unsolved Problems for Sanyo STW1223H2 12000 BTU PTAC AC - Heat Pump With Backup of Electric Heat Air Conditioner RSS Feed
Answer
Ac Doe's not switch off also, heater comes on all modes, even on cool settings.
Answer
The unit no longer blows cold air, it does not appear that the compressor is kicking on. Repair man... (More)
Find a Manual
Sanyo STW1223H2 12000 BTU PTAC AC - Heat Pump With Backup of Electric Heat Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
How to Trouble shoot Low Voltage Controls on AC-Heat
What I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side. A... written by farfield
COMPRESSOR check outs semplified.
If your wondering how to check out your refrigeration compressor; Modern Compressors have two operations that have to work together just to run.... written by farfield
Air Filter changing - easey and often
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date... written by farfield
AC DRAINAGE PIPING REQUIREMENT
Slide 71 .O {color:black; font-size:149%;} a:link {color:#CCCCFF !important;} a:active {color:#3333CC... written by bobotfel
HOW TO CHECK A GOOD REMOTE CONTROL
HOW TO CHECK A GOOD REMOTE CONTROL Using Camera or Cellphone Camera, use the camera as your eye point the remote control transmitter to the camera and... written by bobotfel
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for STW1223H2 12000 BTU PTAC AC - Heat Pump With Backup of Electric Heat Air Conditioner
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
Find an Expert
Meet our 2669 Air Conditioner Experts
projdoc
#1: projdoc
Rank: GuruGuru
Rating:  93%, 613 votes
Solutions:  1205 (473 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
avid101
#2: avid101 Expert Moderator
Rank: GuruGuru
Rating:  87%, 1175 votes
Solutions:  2540 (417 Votes in the last 30 days)
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
roniecon
#3: roniecon
Rank: GuruGuru
Rating:  88%, 664 votes
Solutions:  2209 (362 Votes in the last 30 days)
Experience: A S E certified /35 years experience
justaskjoe
Rank: GuruGuru
Rating:  85%, 2038 votes
Solutions:  3922 (351 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
wracefans24
Rank: GuruGuru
Rating:  86%, 49 votes
Solutions:  340 (340 Votes in the last 30 days)
Experience: Have been working on vehicles since 1973, Have Mopar training,Gm training ,Ford training,
dmftrucker
Rank: GuruGuru
Rating:  87%, 414 votes
Solutions:  1581 (323 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
localwonder
Rank: GuruGuru
Rating:  92%, 2824 votes
Solutions:  4983 (318 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
techbuster
Rank: GuruGuru
Rating:  89%, 521 votes
Solutions:  1134 (259 Votes in the last 30 days)
57 varieties
Rank: GuruGuru
Rating:  88%, 536 votes
Solutions:  1495 (260 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
shastalaker7
Rank: GuruGuru
Air Conditioners ExpertExpert
Rating:  90%, 66 votes
Solutions:  249 (209 Votes in the last 30 days)
Experience: I am a Licensed H.V.A.C.-R. Contractor,33 year Exp.in Homes and Commercial Repairs.Heavy in elect.
Find a Warranty
Sanyo Contact Information
Main support number(800) 421-5013
Email supportsupport@sanyotv.com
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
