20 Most Recent
Pioneer AXD7381 Remote Control Questions & Answers
My pioneer amp 820w blinking blue why?
The blue blinking light on your Pioneer amp could indicate a number of issues. One possible reason is that the amp is in "standby" mode, which means that it is not currently receiving any audio signals. Another possibility is that the amp is experiencing an error or malfunction.
To get a better understanding of the issue, I would recommend checking the user manual for your Pioneer amp. If you don't have the manual, you can try searching for it online using the model number of your amp. You can also try resetting the amp by unplugging it from the power source for a few minutes and then plugging it back in. If the problem persists, it may be time to take your amp to a professional for repair.
11/20/2023 8:53:25 PM •
Pioneer...
Answered
on Nov 20, 2023
Pioneer plasma TV not working with Roku
Looks like it may be too old? Lots of help below, but this seems hopeful.
https://community.roku.com/t5/Roku-setup/Roku-Ultra-with-an-older-HD-plasma-TV-with-1080i-resolution/td-p/561009
Does a Roku Stick Work on Any TV?
The Roku Streaming Stick
4K is designed to be compatible with any TV that has an HDMI port. This means it will work on both smart and non-smart TVs, as long as they have an HDMI connection.
If your TV is analog, don't worry! You can still use the Roku Streaming Stick 4K by using an AV Composite Converter. This will allow you to enjoy all the features of the Roku Streaming Stick on your TV.
All Roku streaming players will work for any television with an HDMI connection, so any Roku player can be connected to a 4K UHD or HDR-compatible television. However, to stream movies and TV shows in 4K UHD or HDR you will need a compatible Roku streaming player and television that supports 4K UHD or HDR.
Jul 24, 2023
Do I need a special TV? - Roku Support
Roku
https://support.roku.com > en-ca > article
Does Roku Work on Any TV? Here's What You Need to Know
The Home Theater DIY
https://thehometheaterdiy.com > does-roku-work-on-a...
2 days ago - Yes, Roku does work on basically any TV as long as it has an HDMI port. Older, lower resolution TV's probably don't need the most updated 4k ...
How to set up your Roku streaming player or ...
Roku
https://support.roku.com > Roku setup
Jul 24, 2023 - From a USB port on your TV Any Roku Streaming Stick supports USB power, but only some Roku players do. If you are connecting your Roku device ...
Roku TV ·
Roku Streaming Stick 4K ·
4K TV ·
Roku Streaming Stick 4K+
Compatibility Unleashed: Does Roku Work on Any TV?
Automate Your Life
https://automatelife.net > does-roku-work-on-any-tv
1 day ago - The Roku Streaming Stick 4K is designed to be compatible with any TV that has an HDMI port. This means it will work on both smart and non-smart ...
Does a Roku Stick Work on... ·
Steps to Install Roku on an Old...
9/9/2023 12:14:19 AM •
Pioneer...
Answered
on Sep 09, 2023
Pioneer vsx1020 wont turn on with telly,if I unplug 15 min from power point does but when turn off telly turn off amp which is good,but if I turn on once again the telly,amp wont turn on
If your Pioneer VSX-1020 receiver is not turning on along with your television, here are a few troubleshooting steps you can try:
- Check the power connections: Ensure that the receiver is properly plugged into a power outlet and that the power cable is securely connected to the back of the unit. Also, check if the power outlet is functioning properly by plugging in another device.
- Reset the receiver: Perform a soft reset by turning off the receiver, unplugging it from the power source, and waiting for about 15 minutes. Then, plug it back in and turn it on. This can help reset any temporary glitches or issues with the receiver's electronics.
- Check the remote control settings: Verify that the remote control is properly set up to control both the television and the receiver. Make sure you have followed the instructions in the receiver's manual for programming the remote control to work with your specific television brand.
- Test with a different HDMI cable: If you are using an HDMI connection between the receiver and the television, try using a different HDMI cable to rule out any potential cable issues. Sometimes, a faulty cable can prevent the devices from properly communicating.
- Update the firmware: Visit the Pioneer website and check if there are any firmware updates available for your receiver model. Updating the firmware can sometimes resolve compatibility issues and improve overall performance.
- Contact customer support: If the issue persists, it may be best to contact Pioneer's customer support for further assistance. They can provide specific troubleshooting steps or advise on whether the receiver may require servicing or repair.
Remember to consult the receiver's manual for additional troubleshooting steps and to ensure you are following the correct procedures for your specific model.
6/18/2023 7:44:46 AM •
Pioneer...
Answered
on Jun 18, 2023
Pioneer VSX-930. The 'FL' light flashing on and off?
Cindy Wells is a trusted Expert here.
- Pioneer Master
- 6,628 Answers
FL OFF could indicate a problem with the power supply or the cooling fan inside the receiver. Try unplugging the unit to reset the error code. If the error persists, the receiver needs to be serviced. If the Pioneer VSX-90 is still under warranty (1 year), contact the manufacturer. Otherwise, decide if it is worth fixing (including the shipping costs and minimum service fee).
I wish that I had better news for you. (There are service manuals available for sale online. I know nothing about these vendors.)
Posted on Nov 28, 2022
https://www.google.com/search?q=Pioneer+VSX-930.+The+%27FL%27+light+flashing+on+and+off
You can take it to any audio technician locally
6/12/2023 6:44:53 PM •
Pioneer...
Answered
on Jun 12, 2023
Pioneer DVL 919 LD player standby light blinking.
Un voyant de veille clignotant sur un lecteur Pioneer DVL-919 LD peut indiquer un certain nombre de probl?mes. Voici quelques causes et solutions potentielles :
- Probl?me d'alimentation : V?rifiez le c?ble d'alimentation et assurez-vous qu'il est correctement branch?. Si c'est le cas, essayez de brancher le lecteur sur une autre prise. Si le voyant de veille continue de clignoter, il se peut qu'il y ait un probl?me avec l'alimentation. Dans ce cas, le lecteur peut avoir besoin d'?tre r?par? par un technicien professionnel.
- Probl?me de plateau de disque : Si le plateau de disque n'est pas correctement ferm?, le lecteur ne s'allumera pas. Assurez-vous que le bac est compl?tement ferm? et verrouill?.
- Probl?me de chargement de disque : Si un disque charg? dans le lecteur cause un probl?me, le lecteur peut ne pas s'allumer. Essayez d'?jecter tous les disques qui se trouvent dans le lecteur et voyez si le voyant de veille cesse de clignoter.
- Probl?me de micrologiciel : dans certains cas, un probl?me de micrologiciel peut ?tre ? l'origine du clignotement du voyant de veille. Essayez de r?initialiser le lecteur ? ses param?tres par d?faut. Pour ce faire, d?branchez le lecteur de la source d'alimentation, attendez quelques minutes, puis rebranchez-le.
Si aucune de ces solutions ne fonctionne, il peut y avoir un probl?me plus grave avec le lecteur qui n?cessite un entretien professionnel.
3/12/2023 8:52:43 PM •
Pioneer...
Answered
on Mar 12, 2023
Pioneer PDP-4340HD TV doens't responding
- Check the input source: Make sure that the TV is set to the correct input source and that the source is working properly.
- Check the HDMI cable: If you are using an HDMI cable, try a different cable to see if that resolves the issue.
- Try a factory reset: If the above steps don't work, you can try a factory reset. This will erase all of your settings and return the TV to its original state. Check the manual for instructions on how to perform a factory reset.
- Contact the manufacturer: If the issue persists, it may be a hardware problem and you may need to contact the manufacturer for a repair or replacement.
Note: Make sure that you have a warranty for the TV or if it's an old one, then it may not be cost-effective to get it repaired.
2/5/2023 8:05:11 PM •
Pioneer...
Answered
on Feb 05, 2023
Pioneer dvr-220 randomly turns off
There might be a connection that could be loose here to have your TV be turning off or there is a problem with the TV's power supply or a Tcon board problem or the power cord might be bad.
1/30/2023 7:07:46 AM •
Pioneer...
Answered
on Jan 30, 2023
Front display not working on Pioneer BDP-65FD DVD player
The issue you're experiencing with the front display not working on your Pioneer BDP-65FD DVD player could be caused by a few different things. Here are some things you can try to fix the problem:
- Check to make sure the power cable is securely plugged into the player and the outlet.
- Try a different power outlet or power source.
- Check the power switch on the back of the player to make sure it is turned on.
- Check the brightness settings on the player to make sure they are not turned down too low.
- Check the contrast settings on the player to make sure they are not turned down too low.
- Inspect the display panel for any physical damage, like a crack or broken wire.
- If the above steps do not resolve the issue, it may be best to take the player to a professional technician or contact the manufacturer for further assistance or service.
It is important to note that, the above steps are general troubleshooting steps, and the actual problem can be caused by different things, so it is best to consult a service manual for your specific Pioneer BDP-65FD DVD player or contact the manufacturer for more detailed and accurate information.
1/23/2023 12:45:29 PM •
Pioneer...
Answered
on Jan 23, 2023
My Pioneer 5020 unit displays sould level but not picture
please double check that all of the inputs for the tv are placed correctly. Then, you can remove any accessories (ie video game consoles) before power cycling your tv.
Otherwise, you can perform a channel scan next before factory resetting your tv.
Thank you.
11/27/2022 9:22:34 PM •
Pioneer...
Answered
on Nov 27, 2022
