20 Most Recent
Ricoh Aficio Mp 2000 Copy Machine Questions & Answers
Hello sir i have a question adf is not working
So my first question is: Have you shut the machine down, unplugged it from the wall, waited 30 minutes then, plug the machine back in, turn it on and listen for the ADF solenoids to cycle indicating it has calibrated and is functional?
I know it sound like the old "ctrl-alt-del" used on pc's only more involved. Please try this and let me know the results.
Problems picking up paper
You should get it checked by an Authorized Service Professional. If this doesn't do, check if your paper is of a compatible weight (GSM) Check your Machine for compatible paper specification and to know this you may read user manual or your machine. Then check your Paper Packet. If your paper is of a compatible weight, you should call authorized service engineer of your machine. If you find you were trying with a non-compatible type of paper, change to a compatible paper and if it still jams, something wrong with your machine is definite. Contact Authorized Service engineer in such a case.
Sc 285 sur un photocopieur ricoh
You either have a torn ITB belt or a faulty ITB belt unit.
If this is not your problem then you could have a faulty ID sensor or a faulty PCU that is causing your Process Controll to fail and generate the SC285.
How can I fix a malfunctioning Ricoh 3410 printer?
On this page see error code 542.
Error Codes > Ricoh > SP3410DN > page 2 (printcopy.info)
- Code: 542
- Description: Fuser reload error
This SC is issued if one of following conditions occurs: The fusing temperature rises 8°C or less in 1.5 seconds; and this continues 5 times consecutively. -or- The fusing temperature has not reached 45°C within 9 seconds (after the fusing lamp comes ON while the machine is warming-up). -or- The fusing unit does not attain reload temperature within 35 s. (normal temperature) or 65 s (lower temperature - the thermistor output is less than 18°C) after the fusing temperature control starts.
