20 Most Recent
Sanyo EM-Z2000S Microwave Oven Questions & Answers
Plugged microwave in a different voltage outlet
Your best thing is to buy a new one..Even if you do find it and install it. It's not guaranteed to work and you'll have a lot of money tied into it.. Microwaves are pretty cheap..Sometimes you'll loose fixing them....But it's your money.
Erratic microwave heating
Your magnetron is failing.
For more help from Emerson
visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by
Fox International and their number is 800-321-6993. Or you might try e-mailing
[email protected]We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Loose Light?
MOST MICROWAVE OVENS TODAY HAVE TO HAVE THE OUTER SLEEVE REMOVED TO ACCESS THE SIGHT BULB.
THIS IS DONE BY REMOVING ALL THE SCREWS ALONG THE BACK EDGE OF THE SLEEVE AND PULLING UP AND
BACKWARDS ON THE SLEEVE. SOMETIMES THE BULB ISN'T LOOSE BUT THE FILAMENT IS DANGLING IN THE LIGHT BULB AND OCCASIONALLY MAKES CONTACT WHEN IT IS BUMPED. THE BULB WOULD NEED REPLACED.
My Sanyo Microwave does not heat up
As it is an older model, I would suspect the magnetron and or capacitor. Maybe the fuse has blown but it will happen again if you just replace it.
Where can I get my door fixed
I would find someone that repairs and fixes small appliances then. I would search on Google and Yahoo small appliance repairs then.
I have a Sanyo Showerwave EM-P672W microwave, that just stopped. Went to heat something up, soon as I went to start it, poof. At the time, it was only about 4 yrs old, & was working fine. I do live in a building that is very, very prone to power surges & fluctuations. Can't count the number of times I've plugged in the vacuum, or used the a/c or garbage disposal, & either had a breaker pop or a safety outlet pop it's mini breaker. I am guessing the microwave has blown a fuse in it due to the power issues? Wanna get another opinion before I bother diving in & getting a new fuse ordered. I do pc tech work, so I am well aware of the dangers working with caps & power supplies.
Mains borne power surges and transients are dangerous to semiconductor devices and especially CMOS devices - any equipment containing these should be provided with surge protection and because almost everything is a computer these days, this means almost everything!
Regarding microwaves - I have been inside quite a few but so far haven't noticed any fuses protecting the control circuitry though there is usually one in the eht circuit. A power surge is unlikely to harm the components of the eht side.
The voltages of the control and timer circuitry are quite normal but those of the eht side are beyond the scope of the ordinary multimeter. I don't have an eht probe so I have never measured it but at various times I have read the voltage is anything from 2000 to 7000 and because it is mostly transformer generated, it is exceptionally dangerous and if the discharge resistor is absent or not working the capacitor can be dangerous for a long time after it has been switched off.
