20 Most Recent Rolex Day-Date President 118238 Wristwatch Questions & Answers
Look at:
https://www.bobswatches.com/rolex-serial-numbers
Rolex Day-Date... | Answered on Oct 08, 2018
counter clockwise. If its locked - take it to a repair shop. Otherwise you can damage it,
You would have to unscrew the back (needs a special tool) and leave it open to dry..then probably have it cleaned. Only a professional watch mender can do this.
BUT Rolex watches are water resistant. It either isnt as Rolex, or you went too deep
Rolex Day-Date... | Answered on Jan 22, 2015
This is a mechanical auto-wind watch. It self winds when worn. But if taken off for a couple of days it will have stopped and won't start running again unless it is wound.
Put it on and wear it for a few minutes. This will wind it enough to start it running again. Then set the time and wear it and you'll be fine.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Rolex Day-Date... | Answered on May 11, 2014
Unscrew the crown,let it pop out by gently turning it towards you , anticlockwise....gently pull the crown out to the first stop and turn the crown......day one way and the date the opposite way. The time is set by pulling the crown out to the next stop.
Rolex Day-Date... | Answered on Apr 04, 2013
i am scared of putting to much force turning the crown
It is very hard or stiff ND CAN'T LIFT CROWN TO BR ABLE TO SET DATE AND TIME
Rolex Day-Date... | Answered on Mar 20, 2013
Hello
I bought one while on a buisness trip to China. I like the watch alot but the band was too big. I have a friend who's a jeweler. He fixed the band for free. It does take a special tool (which he had).
Rolex Day-Date... | Answered on Feb 11, 2012
This watch is self winding and will stop after 2-3 days if not worn.
To wind it up,shake it from side to side gently for a few minutes (about 100-200 times) and this should wind it up sufficient to make it run for some time.
These watches thrive on being used and if you wish to maintain its operation, wear it at least every other day.
Rolex Day-Date... | Answered on Mar 06, 2011
It sounds like your Rolex isnt retaining its power.If worn for 8 hours a Rolex in good condition will hold power for 36 hours.
Rolex watches need regular servicing every 4-5 years so it may be due a service,the mainspring may be broken or the automatic windind may have a fault.
You need an expert Rolex watchmaker to advise you try www.rolexrepairs.co.uk they offer a free estimate and repairs are returned in 2-3 weeks depending on the work.
Rolex Day-Date... | Answered on Aug 19, 2010
Unscrew crown pullout 2 stepsturn hands around till the date changes .this will indicate to you it is midnight .turn ands around to right time.if you are setting this in the afternoon remember to go past the 12.When this is done push winder in 1 step and turn winder clockwise or anti cclocwise and this will let you set day or date. When you finish push winder back in and lock down.
Rolex Day-Date... | Answered on Jul 24, 2010
mcdevito75 here, Most likely the manufacturers ID for that particular band.
Rolex Day-Date... | Answered on Jul 11, 2010
If you don't have this ORIGINAL VALID STAMPED INTERNATIONAL ROLEX WARRANTY then your watch does not have any warranty. Just approach the dealer and ask him for ORIGINAL VALID STAMPED INTERNATIONAL ROLEX WARRANTY otherwise your watch does not have any warranty
Rolex Day-Date President 118238 Wristwatch Logo
56 questions posted
Top Rolex Watches Experts
Arturs Kalnins
Arturs Kalnins
Tom Lambert
Level 1 Expert
Are you a Rolex Watch Expert? Answer questions, earn points and help others
View Most Popular
Rolex Watches
  • Rolex Watches
Most Popular Question
iv rolex watch 2years now not worn
  • Watches
