We have a Heart Interface (Freedom 25) inverter which we keep for our little house in Spain....
(More)
We have a Heart Interface (Freedom 25) inverter which we keep for our little house in Spain. However, last week it blew up after someone put too much power to it. Weve brought it back to uk. Do you know anyone in UK who could mend it. Many thanks. mini
I have a Heart Interface (Freedom 25) that has been working great for years. Last power outage...
(More)
I have a Heart Interface (Freedom 25) that has been working great for years. Last power outage switched on and ran good for the time the power was out (about 2 hours) but when line power came on switched back to grid power but the charger cycled several times and stoped charging. Then no ac output at all. HELP! NB
Went to different RV repair place and they changed the wiring between the inverter and my 4, 6 volt...
(More)
Went to different RV repair place and they changed the wiring between the inverter and my 4, 6 volt batteries to the largest size there is. The distance between them is a bit over six feet. They also added two more ground points. They told me that all inverters should have at least two heavey ground points and that using the largest size wire is always better. It fixed my problems!!
I have problems getting the generator to work since we installed the Xantrex RS3000. it takes...
(More)
I have problems getting the generator to work since we installed the Xantrex RS3000. it takes forever now for the microwave to kick in etc. Not to mention I've popped 5 fuses on the inverter at a hefty price to replace which my installer has informed me is not under warranty? Grrr. The fuses seem to pop only when we use the microwave. That sucks when I have to fire up the generator just to pop something in the microwave for 2 minutes. And now the generator has to run sometimes for 5 minutes or longer before the microwave kicks in. My RV is a 2006 Pace Arrow in mint condition. This kind of sucks.
i want to replace my xantrex freedom 30 with a ms3000. I presently have a link 2000 installed and...
(More)
i want to replace my xantrex freedom 30 with a ms3000. I presently have a link 2000 installed and understand that the controller for the ms3000 does not require a shunt -- that it uses a cat5 cable for control can i replace the freedom and still use the link -- will it control the ms3000
Precise Engine Repair proudly represents Briggs & Str... Read More
Precise Engine Repair proudly represents Briggs & Stratton, Honda, Kohler, Tecumseh, Onan engines and Drainzit oil drain systems. Our goal is to offer free information, along with giving you an outlet to buy genuine original equipment manufacturer (OEM) parts at a discount.
