Sharp R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven
Problems with Sharp R-1610 / R-1611 / R-1612 1000 Watts...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Sharp R-1610 / R-1611 / R-1612 1000...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Sharp R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven RSS Feed
View More Results for Sharp R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven
Questions and Unsolved Support Problems
Unsolved Problems for Sharp R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven RSS Feed
Answer
How to remove from the wall. Where is the location of screws or nut & bolts ? Please help.
Answer
What does the hood assembly on the Sharp R-1611 look like? I don't have the manual, and don't know... (More)
Answer
microwave runs fine but timer display screen is not functioning. Fixable?
Answer
Re:Sharp R-1610 microwaved. The door frame has cracked. This will be the second time we've had to... (More)
Answer
Sharp R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven Need part number for door of a sharp r1610... (More)
Answer
I have a Sharp Model r-1610 and the work/night light does not work. I've changed the bulbs.
Find a Manual
Sharp R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven Manuals & Guides
Tips & Tricks
(Post a New Tip)
This is a test
This is a test test test written by joe123r
Replacing a Turntable Motor on a Microwave
The following advice is for MOST microwave ovens (including over-the-range models). This is a fairly simple repair that can be accomplished without... written by jsrock516
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual. In Whirlpool/Kenmore models this is indicated by a lower case... written by ptishkevich
Microwave works normally but does not heat.
If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor, the rectifier diode.or the magnetron. The... written by ginko
Micorwave ovens - and where's the heat?
A microwave not heating up is caused by one or more of the following - 1) Failed controller board (unlikely if you are getting a clock readout and... written by MrMark52
Troubleshooting Guide
Problem: Totally dead oven. Possible causes: No power to outlet (blown fuse or tripped breaker or GFCI). Blown main fuse - likely due... written by sweet_rascal
CHANGE BULB- GE MICROWAVE # JES1289SK01
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I... written by UNCLEMOE
change lightbulb in Advantium SCB1001 KSS01
I was also told that I would have to pay a technician to come out to replace the interior light bulb in my Advantium speedcook microwave, but after... written by kersti
WikiManual
(Post a New Chapter)
How to Clean a Microwave
Splatters of food from microwaving look bad, smell bad, and decrease the efficiency of your microwave. Fortunately, microwaves aren't hard to clean if... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven
Nationwide | 866-240-3413 | Website
When onsite service is not an option you can count on ... Read More
Nationwide | 423-303-3785 | Website
Microwave, blender, mixer parts delivered ove... Read More
Nationwide | 718-584-3449 | Website
Authorized Service center for Saeco, Gaggia, Spi... Read More
Nationwide | | Website
Owner's Manuals and dough kneading paddles for jus... Read More
Rate and Review the Sharp R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven
Write a review:
Rate this product:
Would you recommend the R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Sharp R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven
Key Features
Microwave Type
Over-the-Range
Cooking Power
1000 Watts
Capacity
1.6 cu. ft.
Convection Cook
Without Convection Cook
Dimensions
Exterior Depth
17.06 in.
Exterior Height
16.38 in.
Exterior Width
29.94 in.
Sharp Contact Information
Main support number1-800-237-4277, 1-800-BE SHARP
Support FAX1-630-378-9981
Describe your problem:
Top Microwave... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
