Also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size, larger size or custom settingsalways click APPLY after making any changes.
Right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add to the Toolbar File Edit View Favorites Tools and Help
On the top of the internet page you should see some tabs file edit view favorites tools and help Click on the view tab on the drop down list you should see a zoom size %
Click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it There might be a menu button on the monitor where you can adjust reduce / expand the screen sizes usually located on the underside of the monitor of course this will depend on your brand of monitor.hope this helps.
1 questions posted
18 Questions
14 Questions
11 Questions
4 Questions
