20 Most Recent
MicroBoards G3PBD-1000 modelo G3 Disc Publisher - BD duplicator, 1 x BD-Writer Type, 8x BD Write Speed, Ink-jet Printing Technology, Color Output Type, 4800 dpi Printing Resolution, 1 x Hi-Speed USB Interfaces, Power supply Type, Microsoft Windows 2000 SP4, Micr Questions & Answers
MY Microboards G4 Disc publisher ink light flashes when turned on . It stoppet working after a power failure .
The flashing ink light on your Microboards G4 Disc publisher could indicate a few possible issues. Here are some troubleshooting steps you can try to fix it:
1. Check ink levels: Ensure that the ink cartridges are properly installed and have enough ink. If the ink levels are low, replace the cartridges.
2. Restart the printer: Turn off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Turn on the printer and check if the ink light still flashes.
3. Reset the printer: Look for a reset button or option in the printer's settings or user manual. Perform a reset to see if it resolves the issue.
4. Clean the ink cartridges: Ink buildup or clogs on the cartridges can cause issues. Remove the cartridges and clean them gently with a lint-free cloth or cotton swab dipped in distilled water. Allow them to dry before reinstalling.
5. Update firmware and drivers: Visit the manufacturer's website and download any available firmware updates or driver software for your printer model. Install them and see if it resolves the problem.
6. Contact customer support: If none of the above steps work, it's best to reach out to Microboards customer support for further assistance. They may be able to provide specific troubleshooting steps or arrange for repairs if needed.
Remember to consult your printer's user manual for any specific instructions or warnings before attempting any troubleshooting steps.
PF Pro printing pale blue instead of black
you are printing composite black instead of pure black.Still problem is the print head not getting all inks (may be air, or you didn't remove some seals on the inks/print head.
Our church QD-DVD MultiDrive duplicator
I suggest you do a system recovery (procedure varies by type of operating system) to a earlier date when the Drive was working ok. also go on the Internet and find the web support site and make sure the drive has the latest Firmware installed. If none of this works then you will likely need to replace the drive.
Microboards PF2. Loading jams after
We have the same problem with some brands of discs. Fan the discs before you load them and/or try another brand of DVD. We like Datasafe or Datawrite
I have a microboards DX-1
I'd recommend calling their support line at 952-556-1639 and asking for a guy named Brochu. I own a DX-1 and he was very helpful and was able to walk me through the process on the phone.
How to identify a genx scanner device for Windows 7
When you have no driver for this Windows version and the former did not work, even in compatibility mode, then try the free program IrfanView. In the File menu first go to Select scanner source. VueScan is also a program supporting many scanners but not free.
How to change tax rate on spl-290 calculator
* Press *N/C/CE *****n* Enter 200* Press the TAX+ *****n* The display will sh*w the t*tal price TAX+ 210* Press the TAX+ *****n again* The display will sh*w the tax am*unt TAX 10* *r the price after tax is $58.5, what is the pre-tax price and tax am*unt:* Press *N/C/CE *****n* Enter 58.5* Press the TAX- *****n* The display will sh*w the pre-tax price TAX- 55.72* Press the TAX- *****n again* The display will sh*w the tax am*unt TAX 2.78
My conlog is showing minus - 11.06 kwh
You mentioned a reading of minus 11.06 kWh. Here's what it means:
Remember that this is a prepaid meter, so the negative value suggests that you've used more energy than what was prepaid
The meter has consumed 11.06 kilowatt-hours (kWh) more energy than it has generated or received.
This negative value indicates that more energy was used than supplied during the specified period.
LED Indicator:
The meter has an LED light that flashes when electricity is consumed.
When you use electricity, the meter balance decreases, and the LED light provides a visual indication of energy flow.
Plz tell me error code 21 how to fix it for ultrasonic comfort 400 nebulizsr
As you know, this is a medical device. I suggest you consult a medical professional about it as it affects your treatment. The device is Japanese in origin. The instruction manuals I encounter are written in Japanese. That may or may not prove to be an impediment to you contacting the company yourself for guidance. I am reluctant to advise you about the equipment as my guidance would be very, very general and your health is much too important for trial and error. A low battery can generate error messages. Turning it off, unplugging it, waiting a few minutes, plugging it back in and turning it on might clear the problem. Some nebulizers have a reset button.; I can't say being unable to read the manual readily. Assuring all its parts are assembled correctly is of course worth doing. The company: Koushin Industries, Inc. (Japan):
Address: 1000-1, Hirakata, Ageo, Saitama, 362-0059, Japan.
Phone: You can reach them at the provided address.
Website: Visit their website for more information: Koushin Industries, Inc. However, I find the information there to be in Japanese. Again, I suggest you consult a medical professional.
