20 Most Recent
Ariens Max Zoom 60 in. 25 HP Kohler Courage Pro V-Twin Zero-Turn Riding Mower Questions & Answers
Mower died when I engaged the cutting blades. Won't restart.
How long has it been since you used it? Could be a clogged carburator filter or bad gasoline. Gasoline left in lawn mowers and other small engines lose their kick after sitting for a fall and winter season. Try removing the carburator cover and take some fresh gas, just about a little less than 1/8 of a cup and pour it in the carburator and try to start the engine. Once it starts cover the carburator with the palm of your hand and then release it and cover again until the machine stays on after you remove your hand. This is called priming the engine.
Ariens Zoom 40 Zero-Turn Mower won't drive
https://lawnmodel.com/ariens-riding-mower-transmission-problems-fixes/#:~:text=A%20worn-out%20or%20broken%20drive%20belt%20will%20also,when%20the%20mower%20is%20running.%20Defective%20pressure%20switch
Mt ariens Ezra 1742 won't spark and start
Check the start relay (not starter solenoid) energizes during crank. If the start relay does not energize then the magneto kill shunt is closed, hence no spark.
Comment for further assistance.
Model 915017 1542 zero-turn mower. How can I remove a deck pulley spindle?
See parts diagram
https://www.ariens.com/en-us/partsdiagrams?aribrand=ARN#/Ariens/915017_(000101_-_)_EZR_1542%2c_15hp_B%26S%2c_42%22_Deck/42%22_Mower_Spindle/6415040015/07200057/y
Likely you will need to remove the deck from the mower.
Then remove the blade, tray, and retainer to expose the woodruff key. Remove key and spindle should slide out of the spindle housing.
