20 Most Recent
Swiss Army Wenger Sportedge Bracelet Watch Questions & Answers
I'm able to set the
your watch is chronograph,. and it is not in the picture. probably your problem is the second hand won,t move, it is because that the sub dial on the lower part it is the real second hand. the big second hand is for the stopwatch. the to sub dial on the upper sides of your watch. the upper button/bumper is to start and stop the stopwatch or the big second hand and the bottom bumper/button is to reset it. i hope this can solve the problem...
I have a wenger 79082
If its working when not wearing the watch,this its bit rare that battery is faulty.But yes it can be problem of weak battery or the battery is proper but not fitted properly.Its getting loose.As when you wear the watch on you hand the hand moves causing the battery to move in.So try one thing.Remove the battery from the watch then clean both the socket where battery is inserted and also clean the battery.Clean it with dry cloth.In the watch clean the battery socket with ear-bud or cotton piece.Then re-insert the battery and recheck.But if the problem is same then try with new replacement battery again.If the problem is same then its the problem of internal mechanism of watch.Some dust collected in between the tiny parts causing it to stop and not letting it to function properly.The watch needs a proper servicing for its internal parts.
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
