20 Most Recent
Twinhead N23PB PC Notebook Questions & Answers
I have a durabook r14k
This is a shot in the dark as I am not familiar with your make or model ... Is there a "D" drive on your computer? Frequently, manufacturers will put a virtual "D" drive on the computer and the original software can be found and reinstalled from there.
Let me know what happens.
Thanks for your question
How to fix when got error message says Could not
do these steps:
1- Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
2- Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
3- In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
4- Select the operating system you wish to fix, and then enter the administrator password.
5- Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
6- You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
7- Type exit to reboot the computer.
Change cmos battery laptop
Tricky for the novice. You have to remove all screws underneath, prise apart case without breaking the loocking plastic clips and then hunt for the battery which may just slide out or be screwed down. It may have helped us if you said what the laptop was
11/3/2017 11:29:44 AM •
Twinhead...
Answered
on Nov 03, 2017
I have a durabook R14K, i need access to bios,
Usually you can acces BIOS by pressing
"DEL" Key duing system startup.
But it also depend on the BIOS manufacturer and version on how to access BIOS
I'm giving you all the key which normally used to access BIOS.
1.DEL
2.ESC
3.F1
4.F2
5.F10
6.F11
7.F12
8.ESC+DEL
try them ,it will surely let you access BIOS.
1/2/2010 12:23:14 PM •
Twinhead...
Answered
on Jan 02, 2010
Cannot install window vista
It is because there is problem with error in harddisk.
For that delete all partition and then create again partition if there is not need to take backup of data.
Try this 4 to 5 times then it works.
Then you can install vista easily.
Also boot computer with vista disk and then enter in recovery console mode then type in prompt "chkdsk /r"
then press "y"
then it fix error on harddiks .
Then check.
Let me know if you need more assistance.
Thanks.
10/16/2009 11:16:56 AM •
Twinhead...
Answered
on Oct 16, 2009
Durabook s13y
Did you try to download all of the updates that are available? You might need to go to the company web site and see if there is a BIOS Flash for your notebook. Vista has a lot of problems that Microsoft can't even explain.
6/19/2008 6:37:10 AM •
Twinhead...
Answered
on Jun 19, 2008
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
