20 Most Recent
American Standard Swan 4 In. Bathroom Faucet with Drain, Chrome Questions & Answers
The cable system on the pop up assembly is not
One of two things can be wrong.The first is the drain plug itself has become disengaged with the plunger inside the drain line. You can check this by pulling up on the drain stopper itself, if it comes all the way out then all you need to do is to reinsert it and give it a little twist to get it reseated on the plunger hook. The other may be the drain handle on the top of the faucet may be disconnected from the rod. Open up the doors underneath the sink and inspect it. The rod should go down and the plunger handle should connect to the rod via a bent metal clip. Ensure it is in the correct position to activate the handle in the drain pipe when the top is pulled up.
9/18/2011 9:31:34 PM •
American...
Answered
on Sep 18, 2011
Clogged sinks and toilets
Never use Draino on a toilet. All pipe cleaning liquids are not really a solution, just a temporary fix.
Since you said that the slow draining is associated with both the toilets and the sinks then I am almost certain that you have a venting issue.
Imagine a drinking straw.....now if you hold your thumb on the end of the straw and bring it up abouve the water level water remains in the straw. This is because air can't get in to replace the water. When your finger is removed then the water flows freely.
As with the straw, your plumbing must also breath. I would bet that one or more vents that are on your roof have become clogged with debrise. Squirrels love to throw nuts and stuff down there to build their nests upon.
Climb up there (safety is a priority) and try running a snake (~$10 at lowes) and see if you hit any obstruction. If so, use the snake to dislodge it.
If you would like, pour water down the vents either by hose or bucket and see if the water backs up. If it does then you have a clog. You can also use the water to try to clear the clog.
Thanks.
4/6/2022 3:13:10 PM •
American...
Answered
on Apr 06, 2022
Speed connect drain will not go down completely
Make sure that the compression nut is not too tight where it could bind up the plunger rod. I'm sure you have probably gotten up under to see if it is hitting anything. Also, make sure that the lift rod is adjusted correctly. I am leaning more towards the unit being bound up some how.
12/10/2018 11:24:22 PM •
American...
Answered
on Dec 10, 2018
American standard 2k-2h still leaks after replaceing sem and nut
Did you replace or reface the seat (the surface in the bottom of the faucet body where the stem's washer "seats" itself to shut off the flow of water? There are special tools for removing the old seats and installing new ones (available from professional plumbing suppliers), or you may be able to renew the seat's surface with a special tool called a seat surfacer.
4/13/2018 10:58:01 PM •
American...
Answered
on Apr 13, 2018
How do i remove bathroom sink drain plug?
If by push pull you mean there is a knob and rod that you use to raise and lower the plug. Look under the sink for a rod extending perpendicular to pipe it will be about 8" long and attach to a linking bar below he push pull rod. Typically there is a small retaining nut that seats around a ball seal on this rod that secures it to the tail piece dropping from sink. Unscrew the retaining nut, slide the rod out and then lift out the plug. You will notice a ring on lower end of the plug piece that you will need to insert the rod thru when reassembling. If you are referring to a fixed twist and drop plug Open it and there will be a set screw on a flat face in the stem portion under the cap. It's usually small straight slot screw but may also be a hex head slot Loosen that screw and the plug will lift off a center peg in the drain assembly.
1/12/2018 10:02:19 PM •
American...
Answered
on Jan 12, 2018
How to replace the trap for kitchen sink..there is
open to drain pipes. remove the collars that hold trap on, sometimes you may need pliers or a pipe wrench to remove.install is reverse of removal the trap is there to contain the gases in drain pipe. if no trap. you will smell sewer water all the time. 1-1/4 for bathroom drains and 1-1/2 for kitchen sink drain.
9/13/2017 12:13:07 AM •
American...
Answered
on Sep 13, 2017
How to fix leaky American Standard single faucet kitchen sink
The A-S single lever kitch faucet is terrible. If it is the one I think it is, then it has three screws that mount the cartridge down into the faucet body.If these are not torqued perfectly evenly, the faucet leaks. I suggest getting a Moen to replace it.
5/20/2017 3:21:33 AM •
American...
Answered
on May 20, 2017
Odor coming from water in my home.
I have had this for no reason it smelt as you say The only thing is you may have disturbed the pipes Odd I know drives you mad , As you say a softener would do the trick . or maybe if your on a well , A well flush but they cost .
3/21/2017 9:59:21 PM •
American...
Answered
on Mar 21, 2017
9C-23H/C American Standard: Does the seat for the stem take an o-ring? I replaced the seats but the drip got worse.
There are three things to replacing a washer seat, after you turn the water off, open the valve before you replace it, most people take the stem nut out first, then putting it back over compresses it unless the valve is open.
Check the seat, this is not the rubber washer at the end of the stem. The seat is in the fixture, most can be removed with a special wrench.
Last but not least is the over tightening the valve to stop the water. Water wont stop instantly and it important to remember that. Turn the water of lightly when you are done, wait a moment to see what happens when the residual water drains. Then tighten more if necessary.
2/23/2016 12:43:17 AM •
American...
Answered
on Feb 23, 2016
