20 Most Recent
Dometic 3313470.012 Refrigerator Cooling Unit 945 with Thermal Fuse Ca Questions & Answers
Can my dometic RM 2400 fridge be repaired?
Yes it can be repaired. A refrigeration engineer will find the leak, repair it and re-gas. If it is very old, you might like to consider a new one, because they are more efficient.
9/19/2021 5:28:08 PM •
Dometic...
Answered
on Sep 19, 2021
I just bought an RV
None of these manual links are good. The only documentation I can find online for the RM2400 is the installation manual. Mine doesn't work. I checked AC power and even ran outside power direct to fridge plug. There is no sound and no cooling. Unlike the other fridges I see online, this one doesn't have a black box or obvious fuses accessible from the bay outside the rv. I'd love to find an actual manual. Nothing works on this fridge and there is nothing online about it. Not even on YouTube. How is that possible?
6/22/2021 6:56:45 AM •
Dometic...
Answered
on Jun 22, 2021
How do I get a operating and trouble shooting manual for a dometic royale rv refrigerator?
Contact the manufacturer,
Absorption refrigeration is an infrequently used alternative to compression refrigeration. Absorption refrigerators use a solution of ammonia and water as refrigerant fluid. A gas flame heats the ammonia and provides the energy that drives the cooling process. These models are generally very simple and have few moving parts. This is a very straightforward process. There are three main principles behind proper operation of an absorption refrigerator. Place the refrigerator on a level surface. Make sure that it is adequately ventilated. Check that the correct heat is being applied in the boiler. As long as there are no leaks, this should be enough for the refrigerator to work properly.
1/31/2021 3:34:28 PM •
Dometic...
Answered
on Jan 31, 2021
