20 Most Recent Dometic DM2652 Americana Fridge Refrigerator Refer 2-Way Small Double Questions & Answers
if voltage going in and nothing to display bad board
Dometic DM2652... | Answered on Jul 07, 2017
replace heater element
Dometic DM2652... | Answered on Jun 21, 2016
if Lp system is ok replace board but check gas line for obstructions if no clicking noise bad board or ignitor
Dometic DM2652... | Answered on Jun 18, 2016
disconnect thermistor let run if ok replace if not bad board
if all other LP devices ok check lines to ignitor if no spark replace board
Dometic DM2652... | Answered on Jun 03, 2016
clean out cobwebs in lines then if no spark see if voltage to spark line if ok replace ignitor if no voltage replace board
remove back access panel two black wires come from board and go into chimney
check heater element
Dometic DM2652... | Answered on May 27, 2016
check LP lines for cobwebs
Ensure that you have 12 volts going to the refrigerator. If you do then it could also be the thermal disc located on the heat stack at the rear of the refrigerator. If you pull both red wires off of the disc and conect them and you get the lights to power up then that thermal disc must be changed. ArctiCold Refrigeration We keep it cold
Dometic DM2652... | Answered on Sep 24, 2014
You will first want to ensure the RV is level.
If the RV is level, then open the rear access vent door on the side of the RV to access the rear of the refrigerator. Feel the coils just above the tank on the cooling system. These coils should be warm to the touch. If they are warm and the refrigerator is not cooling then you will require a replacement cooling unit. Also, the most common area for the Dometic 2652 to leak is just above the propane burner area. If it has leaked, you should see a yellow residue in that area. The cooling unit can be changed in approximately 2-3 hours with no specialized tools needed (Arcticold offers 7 day a week free tech support). The old cooling unit will simply unbolt and the new one bolts in. Check out ArctiCold Refrigeration We keep it cold (the highest quality product available) Arcticold New Cooling units come standard with a Lifetime Warranty. Install instructions are also provided with the cooling unit. Arcticold has locations across North America to provide fast delivery. Arcticold cooling units may be purchased over the phone (1-888-782-6665) or through Ebay- Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
#1 Help Diagnose Video
#2 Install a Arcticold RM2652 Cooling Unit Video
Dometic DM2652... | Answered on Mar 17, 2014
check fuses in back board and fusible link on back wall by chimney
Dometic... | Answered 19 hours ago
This one is easy your thermostat is gone. You may notice the unit never shuts off.
Dometic... | Answered on Jan 13, 2018
For Dometic parts it's usually easy to go through your local RV dealer. Not always the cheapest way, but they'll get the right parts the first time, maybe even have some of what you need on the shelf.
Dometic... | Answered on Jan 11, 2018
Dometic DM2652 Americana Fridge Refrigerator Refer 2-Way Small Double Logo
16 questions posted
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Dometic Refrigerators
Most Popular Question
dometic in rv works gas but not
  • Refrigerators
