20 Most Recent Frigidaire GLTF2940FS 3.5 Cu. Ft. Front Load Washer - White Questions & Answers
HOW DO I TAKE TOP OFF TO REPLACE DOOR SWITCH
you asked for it, you got it. Watch the video, don't break anything. Good luck and please click me helpful.
1/4/2015 9:50:12 PM • Frigidaire... • Answered on Jan 04, 2015
My frigidaire front loader keeps turning off and on and makes a bunch of clicking sound
Replace motor control board
1/3/2015 8:31:08 PM • Frigidaire... • Answered on Jan 03, 2015
Why won't my 4GLTF2940FS front load washer will not spin. It will go though a wash cycle, but when it is time to drain/spin the load it immediatley goes to No Spin, then shuts down. The water drains
Hello friend, I appreciate your post! Based off the information you have provided if your Frigidaire washer is draining and rinsing but not spinning it could be an issue with your timer or motor. I would reset your appliance by disconnecting power to it by unplugging it or flipping the household circuit breaker for ten minutes. If that does not work I would recommend having a technician out to the home to properly diagnose and repair the appliance, since it could be any one of these underlying issues. Hope this helps. -Matt
7/31/2014 2:10:16 PM • Frigidaire... • Answered on Jul 31, 2014
Door won't latch shut
Hello Friend, this is Z. Thank you for your post! There could a few reasons why the door of your Frigidaire washer is not closing properly. First check to ensure that the loading door is closed completely. If you have already double-checked the door closure, check the door strike. More commonly, the door strike can become bent or misaligned over time and may interfere with the connection. If not clear to the naked eye, you can determine if the door strike is good by listening for the lock to attempt to close. If it sounds like that, then it could possibly be the door switch or door lock assembly altogether. Worst case scenario could be that the problem lies with the main control panel. If you have checked the door and the door strike, and both appear to be in working order, you may want to connect with a qualified servicer to diagnose the exact problem. Parts can be costly so having an accurate diagnosis is always the best bet.
6/10/2014 4:29:12 PM • Frigidaire... • Answered on Jun 10, 2014
2answers
E21
WATER IS NOT PUMPING OUT FAST ENOUGH. CHECK THE DRAIN FILTER AND SEE IF IT IS CLOGGED If you need further help, I’m available over the phone at https://www.6ya.com/expert/elite_9cbd96cb0728162b
9/29/2013 9:38:26 PM • Frigidaire... • Answered on Sep 29, 2013
Not spinning
Its likely you need a new motor speed control board, its the most commonly replaced board in these washers.On this model its located underneath on the right or left wall.You can't really test this but try putting the washer in to the Spin and Rinse cycle, if it doesn't spin then that is most likely your trouble.I did a quick Google search and found this page for the part:http://www.appliancepartspros.com/frigidaire-control-board-134743500-ap3891780.html
4/5/2013 2:51:13 PM • Frigidaire... • Answered on Apr 05, 2013
CODE E56 COMES UP BUT MOTOR IS GOOD WHAT ESLE CAN BE WRONG WITH IT
Go to the following website there is a diagnostic flowchart that can helphttp://www.appliancepartsquick.com/FrigidaireWasherFaultCodes.html
10/18/2012 6:07:39 PM • Frigidaire... • Answered on Oct 18, 2012
2answers
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you! I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
3/20/2024 3:24:35 AM • Frigidaire... • Answered on Mar 20, 2024
Frigidaire Front Load washer (25 yrs old) fills completely but does not spin for the wash cycle. Manual timer clicks and buzzes but drum does not spin nor does the timer advance.
Sure sounds like your timer has bit the dust. I'm not sure if the timer is still available. You have a great washer there. Good luck.
2/11/2024 4:24:20 PM • Frigidaire... • Answered on Feb 11, 2024
My Frigidaire FWAC 19B5MSGNW washing machine won't move on from the spin cycle. The light is on and if I fill it up with water it will pump out the water but the spin light will not come off.
The machine does not exist as you have written it. There are two likely reasons The door switch has failed and hasn't passed the self test procedure. or the control board / timer has failed. Try power cycling it. Remove the mains plug for an hour. It is has an On Off button press it for a minute. For a knob, full it and leave two minutes. Plug back in and try again. https://www.google.com/search?q=Frigidaire+FWAC+19B5MSGNW ..
1/2/2024 11:12:23 PM • Frigidaire... • Answered on Jan 02, 2024
Frigidaire front load washer door locked
crowbar?
5/15/2023 1:33:24 PM • Frigidaire... • Answered on May 15, 2023
What's stopping my dryer from running continuously
Hi, Please power cycle your dryer and attempt to run it again. If this fails, please ensure that your clothes are evenly distributed so that they weight of the clothes doesn't cause the dryer to be shutdown. Just to double check, please ensure that you've cleaned the lint track of your dryer. Lastly, you can use an power outlet extender to help switch the power outlet that you're using to run your dryer as there might be something wrong with your current one. Thank you.
1/8/2023 1:32:57 AM • Frigidaire... • Answered on Jan 08, 2023
My Frigidaire dryer won't run longer than 5 secs what's wrong how can I fix
There could be several issues that could cause your Frigidaire dryer to stop running after just a few seconds. Here are a few potential problems to consider:
  1. Thermal fuse: The thermal fuse is a safety device that shuts off the dryer if it overheats. If the fuse has blown, the dryer will not run.
  2. Clogged dryer vent: If the dryer vent is clogged, it can cause the dryer to overheat, which could trip the thermal fuse.
  3. Faulty cycling thermostat: The cycling thermostat regulates the dryer's temperature. If it's faulty, the dryer may not run for more than a few seconds.
  4. Faulty start switch: If the start switch is faulty, it could prevent the dryer from running.
  5. Faulty door switch: The door switch prevents the dryer from running when the door is open. If the switch is faulty, the dryer may not run.
To fix the problem, you'll need to diagnose which of these issues is causing the problem and then replace the faulty part. I recommend having a mechanic diagnose and fix the problem for you.
1/8/2023 1:18:38 AM • Frigidaire... • Answered on Jan 08, 2023
3answers
WHAT IS E11 ERROR CODE IN MICROWAVE FRIGIDAIRE
The E11 error code indicates a problem with the gas sensor DE32-60011A and or the wire harness DE39-40678D. Unfortunately the manufacturer has discontinued the sensor. You may want to try contacting local parts dealers, one of them might still have it in stock. Enter your part number in a search engine, a smaller company might have it or try eBay, Amazon or similar sites . Search by using the manufacturers part number. Try a used appliance store, sometimes they have the same model or a usable part for your machine.
12/23/2022 7:33:43 AM • Frigidaire... • Answered on Dec 23, 2022
Frigidaire GLTF2940FS 3.5 Cu. Ft. Front Load Washer - White Logo
Popular Tags
18 questions posted
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
not spinning
  • Washing Machines
