20 Most Recent
Waring JEX 328 Health Juicer Questions & Answers
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Is it possible to blow a fuse in the JEX 328?
yes it has a thermal fuse inside, small as an aspirin rated at 8-10 amps about $ 5.00 us we have replaced most with a reset button circuit breaker , best idea I came up with for $ 12.00 us
Hi--I have a JEX328 juicer,
Here is the manual.
http://www.waringproducts.com/ret/share/man/12_man.pdf
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Is the WE100PC Waring Juicer the same as the
Yes, the JEX328 is the same machine as the WE100PC. All the external parts (the ones you can replace yourself) are the same from model to model. Having inspected both machines and checked parts lists (excluding internal parts), Any part number that fits one will fit the other. There are probably no differences inside the units, truth be told.
I require the instruction manual for a white
COpy and Paste any of these links in your address bar.
Here is the link for a wiring diagram
www.howtomendit.com/answers.php?id=128502
Manual links;
www.ciao.co.uk/White_Knight_44AW__Review_5857836
or retrevo.com, repairclinic.com, appliancepros.com, or appliance411.com
Waring juicer directions missing
I had the same problem...I just acquired the WE100PC without any owners manual. I called WARING's toll free number and they are sending me the manual...no charge. Give them a call! (1-800-492-7464....prompt #1)
Owners Manual
Bought an open box Waring JEX 328 from Linens and Things (going out of business so need to return quick if it is defective) and plugged it in and nothing happened! So now trying to figure out if all pieces are in their correct place. There are two small plastic pieces that seem to go together a smaller angled black piece and a long light plastic piece. Any thoughts? Is there an auto kill switch on these if something is not assembled right?
Juicer problem
The fuse blew on mine, that could be it. I'm looking for a replacement fuse.
Fuse blown
If you are sure that it is your fuse that had blown then you can get a fuse from any electronics store.yo can order it from www.dalbani.com good luck.or from www.best-bosch.com
