20 Most Recent UTStarcom CDM7025 Cellular Phone Questions & Answers
This a 12 year old phone.
UTStarcom CDM7025 Google Search
If removing the battery and reinstalling it doesn't work, I think you need a new one. That error message doesn't appear on any searches relating to a phone.
phone DATA ABORT Ox Google Search
You could try a Hard Reset, which clears everything off the phone, although it seems to indicate, it just deletes things you have saved. One a 'normal', 'modern' phone a hard reset reloads the operating system.
UTStarcom CDM7025 User Manual Default Settings Reset Phone
UTStarcom... | Answered on Dec 09, 2017
For this problem contact your mobile service provider........
UTStarcom... | Answered on Oct 07, 2011
If you've got a usb cord for it, you may be able to connect it to your pc.
If not, try blue-toothing the photos to a phone that can connect to the pc.
If it's activated, you could MMS it to your email and get them that way.
UTStarcom... | Answered on Mar 01, 2011
You can generally get a free unlock code for your mobile handset by calling up your cell phone carrier and requesting one. In exchange they will need you phone's IMEI number which you can get by typing *#06# on your dial pad. If you cannot get a free unlock code, I would suggest looking through these unlock codes and guides. I hope this helps you and good luck!
UTStarcom... | Answered on Dec 19, 2010
JUST F.Y.I....BEFORE YOU or ANYONE ELSE.... PAY TO UNLOCK THERE PHONE....DID YOU KNOW OR TRY THIS !
Ok i just had the same thing wrong with my phone.....locked out reading on here...i 1st tried 0000,did not work ....them next i tried1234,did not work...the phone i have is the-
UTStarcom7126c it was only used on one cricket phone/account before i got it... my brother bought new.....so i was told,if it wasn't the 0000 or 1234 it would be the last 4 digits of the phone number if it hadn't been changed from factory default...and had said,he had never changed the lock code on it the whole time he used it....that had to be it!...easy enough...i typed in his last 4 digits.....nope,nothing! incorrect code!!
He has had the same cricket number the whole time he used it...same number he has had,since2006... long before he upgraded to this one(the UTStarcom7126c)early last year.....when he upgraded to his new phone a few months ago... his number stayed the same.....he wasn't using it any more....so when my mine took a swim,i got it from him.....and i called cricket and transferred my number to it( few weeks back)....i tried to master clear it,to empty his phone book, before i started adding my numbers to it....it asked me for the code, i didn't have it, so...i just used it as is....But! i knew it had one....
Well earlier today.... i some how locked it! and none of the four solution's or lock codes i could find on here was workin for me....the only other thing i could find on here was ,short of dealin with cricket......was the post about using the software to unlock it......but for a fee,while online unlocking it through the internet......so i was lookin for the link and about to just pay to fix it! that is when i found the the key, missing link.....the part i was missing! or more like,had just been overlooking...
The key missing information.....
out of all the posts on here that all said the same thing.......finally! i found a post that explained it a little better, than,,,,its either 0000,1234,the last 4 digits or its PAY!
Well,was in the post (that i copied&added below ) i found out all the other were all right! except for the missing part....about the last 4 digits that will unlock it........changing to whatever the last for digits are of the new phone number is,whether was used phone on a different cricket account or even the same account & phone....if the # changes on a phone through the your service provider.....for what ever reason....the default last 4 digit lock code follows it,and changes to the last 4 of the new phone #
i had this happen also and i had my number changed then my cuzin locked my but my code changed to my new # try the last 4 numbers of the new number and try the hole number with out the area code..
UTStarcom... | Answered on Dec 13, 2010
Hi.. visit to the given link for manual.. http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/CDM7025-_E
...hope this has helped you,,., thanks..
UTStarcom... | Answered on Sep 30, 2010
How can I download songs(mp3) to my utstarcom cmd 7126?
Thanks, gem6can1
UTStarcom... | Answered on Aug 10, 2010
Mine unlocked using the last four digits of my phone number.
UTStarcom... | Answered on Jul 15, 2010
trying to download utstarcom driver to my computer , do you have a solution
UTStarcom... | Answered on Jun 20, 2010
the truth is that you can unlock the phone for free,but you can't unlock all phone for free.
The payment sites are very very cheap you could try it out and see.
There is a free site you can try out first but it is for soft
unlock not hard unlock.You can use this link for the soft unlock,
(www.unlocktotalk.com/UnlockCodeInstructions.htm),
you can try out the hard unlock with the site below
Note: hard unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider
and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can
get a free unlock code.
Visit the link below if you are interested in buying the unlock code:
(mobileunlocked.com/mobile_unlocking.php)
Good luck.
UTStarcom... | Answered on Jun 17, 2010
The problem with the phone screen is that the flex on the screen of the phone is worn or malfunctioning, that is why your display is blank atimes.
All you need to do is to replace the flex on the screen of your phone and you will see that the display will be stable.
Just change the flex on the phone and you will see that the problem is solve.
Take care.
UTStarcom... | Answered on Jun 11, 2010
Try using the Last 4 Digits of the Mobile.
Let me know,if the problem remains unresolved.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
UTStarcom... | Answered on Jun 06, 2010
have you tried with the last four digits on your phone number?
UTStarcom... | Answered on May 19, 2010
And your laptop has windows? XP? Vista? Windows 7?
UTStarcom... | Answered on Apr 18, 2010
try 1234, 0000, and the last 4 digits of your phone number
UTStarcom... | Answered on Jan 31, 2010
UTStarcom CDM7025 Cellular Phone Logo
65 questions posted
Top UTStarcom Cell Phones Experts
Andrew Taylor
Andrew Taylor
Unlockingcom
Marvin
Marvin
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • UTStarcom Cell Phones
Most Popular Question
unlock security codes
  • Cell Phones
