20 Most Recent
BenQ M7 Cellular Phone Questions & Answers
Cara membuka kode hp nokia biasa
Hi if you want to unlock your Nokia mobile from network lock ..Then have a look at sites like
MobileUnlockSolutions.com here they are rendering unlock code for all mobile models ..You first verify that whether they are rendering code for your mobile model ,country and network provider ..If yes then pay for it and unlock your phone ....
I need free unlock code for BenQ S660C
hi there are many online providers found in the net that render the unlock codes at free of cost ,but they provide the codes for only older mobile models .you can get the codes from this site
unlocking4u to unlock your benq s660c mobile .here they ask the imei number of the mobile .finally they will send you the codes to unlock your mobile.
Benq-siemens e61 network lock is blocked
You will probably find a number of companies via google a I have used a couple, which I'm not sure I'm allowed to post here so I recommend you visit
Unlock-Zone.com, which is nearly perfect and they were recommended highly in the cell phone forums.
What happen when the number i dialed is not in
That means that either the person you were trying to call
had their account suspended, or you have the wrong number.
For some carriers you may get the error/message because their
phone/themselves are out of area and have no available signal/service.
My daughter has a Benq
Suitable by size or brand?
This is a how long is a piece of string question. Suitability in size is in relation to what you can afford and also the usage you put thwe drive to.
Frankly I would be buying an external drive of say 500Mb that plugs via USB and requires no other power source. They are quite small in size and portable and are more reliable in the face of disk crashes as data can be easily transported to another PC to continue working whilst the laptop is being recovered There are many brands on special from 300HB to I Tb all you need to do is search the discount sellers. LG Toshiba Sharp all have these tiny portable drives that are big on capacity.
Please rate my help++++Thanks for using FIXYA
One cellphone for cdma and gsm both the connection.
As far as I know there's no device supporting CDMA/GSM yet. Although some GSM phones are tri&quad bands is nothing to do with it. The CDMA is totally different system as GSM. Let say comparing diesel engine with petrol engine.
Locked mobile phone
Is it asking for PUK code?
If thats the case you can call up the customer service and get that code from them.
I turned my phone off
PIN stands for Personal Identification Number found in a sim pack as yu purchase it,printed in a piece of paper, u should have kept it.
Usually it has "pin1" and "pin2" which is both "1234" but if u had change it,it is surely differnt right now
If u haven't, try to enter the digits 1234. By the way....pin1 and pin2 is accompanied with "puk1" and "puk2". I hope i've supplied the right solution.
Problem with my benq-df61 mobile
I wonder if I told you how I found the fix whether you would use the information for use on your website.
The solution was eventually really simple and based on initial simple maintanance.
kind regards
Steve
