20 Most Recent
HP Compaq 6715b Notebook Questions & Answers
My laptop never power on
1,check power supply.
2,check battery.
3,check ram.
4,check the fan is running ok.
5,check fuse in plug.
let me know how you get on.
Hp compaq 6715b charging problem
Good day .If i was in the your position i would carry the laptop to a repair shop and let them check it and maybe change the charging port of the laptop
Regular beep every second
Its sounds like one of the memory chips in your laptop may be dying. If there are two memory chips in the laptop, try taking one of them out, and then reboot. If the bad slice is left in alone, the unit won't start at all. Its never easy, hope that helps.
Hp 6715b vga's to external display fine, but no
Hi, First push your FN- and the F- button that has the display symbol it may be set to the external screen. Can you see anything on the screen if you hold a flashlight close to it? If so I would say your back light went out and will need to be replaced. If this is not the case, recheck your cable and make sure it is grounded properly.Also check the sleep button, This should be located above the keyboard. Sometimes it gets stuck.Robert Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/robert_33deecd2f8e91168
Don't have light on LCD screen
you can RUN the software diagnostic coming with the computer or download the s.diagnostic from your computer supplier.However you must restar the computer HOLD the keys CTRL+f11 or f12 depend of your mark, and go to restore at factory default and try it.If the problem persist, is time to go to the repair shop, control board defective or screen faulty.God bless you
Compaq 6715b not finding hard drive
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Power-on Password
b> If your HP Compaq 6715B laptop is lost or stolen, the power-on password can protect the valuable data on your computer. Even so, there may be times you'll want to clear that password and knowing the right procedure will make that easier. Once the power-on password is cleared, the Compaq 6715B will no longer require you to enter a password just to start up your laptop. Shut down your Compaq 6715B and wait for it to power off. Press the "Power" button to restart the laptop. Tap the "F10" key after the Compaq splash screen appears. Wait for the setup menu to appear. Use the arrow keys to navigate to the "Security" menu and scroll down to the "Power On Password" option. Delete the entries in both boxes, then press the "F10" key. Choose the "Save Changes and Exit" option to exit the setup menu. Wait for the laptop to restart and verify that the laptop does not prompt for a power-on password. Hope this helps.
