20 Most Recent Acer Aspire 5520-5156 Laptop Questions & Answers
Hi here you've got link to service manual I hope it help
Acer Aspire... | Answered Yesterday
Hi, Every PC-Laptop has BIOS otherwise nothing would work at all. Try turning the PC on & hold down ALT & F4 together that should get you into the BIOS. As far as having no display then your Video card must be not working & needs replacing. Please leave me feed back: Malcolm Campbell, Thanks.
Acer Aspire... | Answered on Nov 06, 2017
you need a new battery, sounds like either your hard drive is bad or you need to reload the operating system software
Acer Aspire... | Answered on Dec 09, 2015
how did you get waterdrops on the CPU it should be covered with a heatsink.
Acer Aspire... | Answered on Mar 04, 2015
Not uncommon. Try using a registry cleaning programme.
Acer Aspire... | Answered on Nov 22, 2014
Usually a bit of house cleaning will help. You need to disable unnecessary startup/running processes/programs. Your specs say your OS is Windows Vista, use this procedure to speedup: http://www.pcworld.com/article/143538/windows_vista.html Try two freeware programs, 1, CCLEANER: http://www.filehippo.com/download_ccleaner/ This freeware program has many useful tools the cleaner and registry will remove junk and free up HDD space. In the TOOLS section, select STARTUP, disable ALL unnecessary startup programs. In the UNINSTALL section remove all unnecessary programs. 2, MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the Trial Pro version, you want the freeware version, run a FULL scan, delete ALL results, reboot. Remove ALL toolbars and unnecessary Extensions from your web browsers. The sidebar is a memory hog, consider adding more memory. If your version of windows vista is 32 bit, it will only support 3.80+or-GBs so 4GBs would be the limit. Have you cleaned the fan, vents, and heatsink lately? Use a can of compressed Air to remove dust, dirt to restore air flow. You could always do a Full Factory Recovery, but that would be a last resort, it can be quite a long process.
Acer Aspire... | Answered on May 26, 2013
Run recovery from your install disk
Acer Aspire... | Answered on Mar 16, 2013
Stops? Powers off? Can you explain what happens in detail? Unplug, remove battery, plug in, boot, what happens, Windows Logo appears, then what?
Acer Aspire... | Answered on Dec 31, 2012
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps
Acer Aspire... | Answered on Jul 25, 2012
I suggest to download and install the windows live suite ..and this will also install windows live messenger (latest ) ..and windows live mail ..
To get it ..just download this ..and run into computer
http://explore.live.com/messenger
on this link in teh right of the page you have the installer for the windows live suite ..and will install all in your computer ..just select them in the list when installing ..
to connect to the mail you can also get to the web page . and insert the mail and the password..
here is the link for the mail .page
https://login.live.com/login.srf?wa=wsignin1.0&rpsnv=11&ct=1325439927&rver=6.1.6195.0&wp=LBI&wreply=http:%2F%2Fexplore.live.com%2Fhotmail&lc=1033&id=269505&mkt=en-US
It basically same page ..but you have to click on the sign in ..
To use the mail you can also use teh windows live mail after installing in your computer ..If it does not make a short cut on the desktop ..you will find them in the all programs in the start ..
to get them on the desktop just click right on icon in the start menu ..and select send to desktop ..
Acer Aspire... | Answered on Jan 08, 2012
Copy and paste this link http://tim.id.au/laptops/acer/aspire%205520%205220.pdf
Acer Aspire... | Answered on Nov 13, 2011
yes.. of course...but you need an installer..
do you have one??
for further instructions you can email me at to stormblade002@yahoo.com
rate me...
Acer Aspire... | Answered on Oct 09, 2011
Hi
you could try this
go to the start button
go to the search box
and type in cmd
this may bring up a black box
type into the box chkdsk
and windows may check and poss repair the disk for you
failing that
restart the laptop pressing the F8 key
this may take you into a repair options box
try some of these options
my first choice is asways the last known good configuration option
and if that dont work
i go through the other options of repair
good luck
hope this will help you
Acer Aspire... | Answered on Mar 25, 2011
Remove the power adapter and battery from the laptop.
Remove the plastic buttons bezel. This is where the power button and some LED lights are. There are usually indentations on one of the sides that will help you to lift it up. It's held in by clips, so be careful as these bezels snap easily if they flex too much. Now remove the screws holding in the keyboard. Lift the keyboard up very very slowly until you see the ribbon cable that connects it to the laptop's motherboard. Lift the tab on the connecter and pull the cable out carefully. You have now removed they keyboard.
Good luck.
Acer Aspire... | Answered on Mar 08, 2011
Take the battery out and hook the machine up to the AC power and try it again.
Acer Aspire... | Answered on Feb 03, 2011
HI
if you go to www.ebay.com and go to catagories and search laptops find the search bar and look for acer aspire 5520 screens you should find several places selling them
depending on what sort you go for i think they range from about £60 - £75 ish for a shinny glossy one
happy searching
Acer Aspire... | Answered on Jan 27, 2011
type in msconfig in the run box or in a CMD box (open as admin) then retick the entry Acer Backup Manager in the start up tab. Reboot and you shoud be prompted to make a new set of back up disks.
Acer Aspire... | Answered on Jan 03, 2011
hello:
control the settings in your web browser set to back fact defaults
have nothing to do with acer laptop
i think you have change somthing in the browser.
have before alsoprobl with it reset to default!!!!!
Acer Aspire... | Answered on Dec 19, 2010
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Acer Aspire... | Answered on Dec 17, 2010
Acer Aspire 5520-5156 Laptop Logo
Popular Tags
78 questions posted
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
acer laptop using vista outlook 7
  • Computers & Internet
